Jbender5,
The bulging phenomenon referred to earlier in this thread is called creep in the engineering world. If the aforementioned installation "bulged", it was either the wrong strength material to begin with, or it was backfilled with the wrong material, causing an overload. Regarding this, vinyl/composite walls should never be backfilled with fill dirt, especially if the material contains clay. Fill dirt can retain significant quantities of water, and put a lot more weight/stress/load on the wall than it is designed for. This is a common mistake in the field. In almost all cases, the proper fill material is sand. Beyond that, insisting on the proper anchoring system, rather than a less expensive "budget" version will alleviate any chance of a wall "falling over" as also mentioned earlier in the thread.
Other issues to consider: Sheet piles should have at least as much material in the ground as the wall height extending above the sea bed. Also, anchor rods should always be 2.5 to 3 times as long as the height of the wall measuring from firm sea floor to the top of the wall.
As far as pilings go for the entire wall, they may not be necessary at all depending on the height of the wall, and the whaler system utilized. There are formulas and tables for this computation. Pilings would be a good idea in the boat area though.
Regarding all this, here's a good place to do some research prior to pulling the trigger on your installation.
http://www.cmiengineer.com/product-engineering.php It is well worth designing the wall properly from the beginning, to insure a lasting installation. That said, and considering the relatively elementary computations at hand, having the loads evaluated by an engineering firm should be relatively inexpensive, and would be the best money you ever spend during the process of constructing your new wall. With that load data in hand, you can choose the proper materials for the job, ultimately averting problems which most often emerge down the road...long after the installation is complete.
Good luck.
