Need Oil Filter Crossover Data
gcolton
Well-known member
I have the part number for the MerCruiser oil filters for the 350 MPI Mags on my boat. I would like to get a cross reference to another make of filter. I would prefer to use Mobil 1. The problem is that I have not been able to find a cross reference at West Marine, Advance Auto nor Auto Zone. Does anybody have any ideas?
Thanks.
George
Try this number, Mobil1 Oil Filter Hotline 1-800-882-0890.
Usually you can go online for some companies to obtain crossover numbers.
George, the AC Delco equivalent to the Volvo 350 is a PF1218. It replaced the old PF35 filters that were used for 30 years.
Thanks for the replies. The Pure Oil site did not have crossover data. I will telephone Mobil Monday and see if they can do any better.
The problem that I have found so far is that all of the companies are set up to check crossover data for other filter makers in the AUTOMOBILE industry.
G
My opinion may vary from others, but the engine is a Chevrolet. When it is disassembled, the only difference in the Marine version vs. the truck version is brass in the cooling, there is no smog control on the marine engines, and all accessories are different. But as far as the internal oil system, is is 100% automotive.
With all that said, when I went to the mobile 1 site, plugged in all the info on a chevy suburban it gave me these 2 choices:
Mobil 1 Model M1-201
Mobil 1 Model M1-302
EDIT: looking up a different year model that uses the large diameter filter listed only one choice: Mobil 1 Model M1-302
Using the Mobil website is more difficult that going to the parts store and cross referencing the AC Delco PF-35.
Good thought meddkatt. I will look into that. The oil filter is mounted remot from the normal place. Do not know if that will have any bearing. I had thought of taking off a current filter, cleaning it up and taking it to the parts house. However, that is such a dirty job.
Thanks again.
G
Go to the parts store, pick up the one out of that list that looks the same height. When you remove the old filter, compare them. The diameter and height should be nearly identical, the threaded mounting hole must have the correct threads(it should spin on with no effort), the multiple holes that are between the gasket and the mounting hole may vary slightly, nothing to worry about.
This way, you do not have to clean up a dirty oil filter, however if you feel you need to take it with you, a 2 liter coke bottle with the top cut off makes a good transportation device.
BIG EDIT HERE: another link gave me the following filter: Mobil 1 Model M1-302
The first look up I did was for the engines that had the skinny filter!
If your oil filter is remote mounted, most of the time it take a Motorcraft FL-1 filter. All the GM based engines I have had with remote filter used the Ford oil filter. You can cross the FL-1 over to any brand you want to.
More thanks guys.
This is the short, squat filter. I would much rather pay About $10 for a better Mobil filter than $12.95 for a MerCruiser filter.
G
Take your filter number to a NAPA store. They crossed my remote volvo filter to theirs with no problem at all. After that you can cross the NAPA filter easily. Tom
Don't forget to post the Mobil part number when you get it.
George,
An excellent filter for the MerC 350 is NAPA's 1060 Gold. Made by Wix...there are none better.
I just hung up from talking to Mobil.
The filter part number that I was looking for is 35-866340Q(03). The Mobil man could not find this number but he could find the equivalent for (02).
I then called Merc and Rocky said it is the same filter, just an updated part number.
The recomended Mobil filter is M1-111.
muddkatt, he also said that the M1-302 that you recommended should work if there is space.
Many thanks for all of the help.
I will also check into the NAPA 1060 gold.
George
