Need Some Advise
skinnydippin
2001 Larson Cabrio 220 Sport Cuddy w/Volvo Penta 5.0L GI 250hp. Recently, my boat wouldn't start so I had a boat shop look at it. Somehow I got water in the engine, damaged valves, heads, anything else you would expect. Volvo wants a small fortune for an engine. Can't buy just a block from them. Any suggestions about the best way to do this. I'd like to get a used block w/heads no older than maybe 03 and fuel injected. I live in SE Alabama, boat is in Panama City FL. Would travel within reason for Volvo Marine block with minimum 30 to 60 day guarantee. Anyone know a reputable person in this area for contact?
Warranty covered due to a lower than required static line? Volvo Issue? Tough case.
Jasper will have the correct replacement.
This should be a Ford 302 CI block--do a Google search for re-manufactured 302 Ford marine engines. There are a bunch available. Or you may want to upside the block and go with more HP--and the injected engine.
Jasper, Jasper, Jasper, oh, did I mention Jasper? If you have to spend your own money, do it rite, do it once. ALso, check what Kida said, you may have a silent warrenty on this issue, worth the look, you have all winter now. And add the name Jasper to your vocabulary, you wont regret it...D.........
Are you positive your engine is a goner? Or is the shop trying to milk it? It could be something like a lose wire or such. Confirm the damage and need to replace the block before you spend the $$$$$.
Who is Jasper, D?
Jasper Engine e-mans. I put a Jasper long block in a boat once whose stbd engine ingested water. Good prce, great waranty (on paper) and used the boat for a couple more problem free years before I traded it in . The engine is still going strong about 7 years later.
Yes, please do an Engines Forum post and include engine type and issue in the title. You'll get more play on it that way.
By "required static line" KiDa means there is a minimum height that the riser tops should be above the boat's loaded waterline. For MerC it's 13" and ours has 3" spacer blocks between manifold and riser to accomplish this. If the manufacturer failed to do have at least minimum static, you may have recourse/silent warranty as noted above.
Volvo discontinued "flappers" in their exhaust WYE-pipes awhile ago. They were on the order of the flaps you see over the transom exhausts on some inboards. Purpose to keep water approaching from the stern from continuing forward then up and over in the riser/elbows and into the engine. Any odd operating conditions before the problem like:
Heavy load astern
Backing down hard
Stopping suddenly
Engine dieseling/running on at shutdown
Engine otherwise coughing/missing
Anchoring or docking with transom facing chop, waves, boat wakes
You are also at the end of the useful life of cast iron exhaust parts in a saltwater environment and a raw water cooled engine. Or, have they been replaced and if so when...?
If you're sure the engine is badly damaged [full rebuild, replace cam and crankshaft, etc. then take my good friend D.Andrews advise and investigate Jasper.
