bilge pumps and switches come with detailed instructions and wiring diagram... impossible to help ou if you dont' even say what kind of pump you bought, what kind of float switch, etc...
as jim suggested, get a voltmeter and see what those 4 wires do... that's the only way to be sure. you should have a positive coming from the switch at the dash , another positive wire coming from the battery or a breaker and usually only one negative wire. no need for two but maybe that's what you have. only way to know is to check.
the switched wire from teh dash goes to the pump, the always on wire goes to the float switch. how depends on the pump model, but again the instrcutions should be clear
