Neutra salt system
cigarman
I have a Four Winns 2005 vista 288 with volvo ocean series outdrives. I have a problem with the neutra salt system in the port engine that it is not working. I can't find any wiring diagrams and I assume it is gravity fed with a soleniod controlling the switch from the dash board. Is there anything I should be checking and where can I buy parts if needed.
If you have a filter between the Neutra Salt container and the solenoid, it may be clogged.
To check the solenoid, turn your ignition switch to on, but do not start the engine. Press the Neutra Salt switch for the port engine. If you hear a click, the solenoid is OK, but there is most likely a clogged filter.
If you do not have a filter, then the solenoid is clogged. Disassemble the solenoid, and blow it out to clear the clog. Also, remove the container, and dump out the Neutra Salt solution. You may have some gunk on the bottom of the container. Claen out the gunk, check the hoses for clogs, refill the container with fresh Neutra Salt solution, and you should be good to go.
The same thing happend on our Chaparral Sig 290, and the above procedure got the system running again.
It's a very simple system and there shoiuld be no filter in the line. The bottom of the tank has what looks like a filter but is really a check valve.
First thing I would do is remove the hose between the solenod valve and the engine. Turn the ignition to the on position and depress the switch. You should have solution coming out of the valve. If not, the valve is either bad, you have no power to the valve or there is a clog somewhere like Abrams said.
You can pull the hose off the container side of the valve to see if solution comes out that way. If it doesn't come out, it could be the check valve in the tank. This check valve prevent air from being sucked into the hose when the container is empty. You need this valve so don't bypass it if it is not working. If the tank is empty and air is allowed into the raw water pump, you could damage the pump.
Thanks for all the great information. I'll start checking it out tomorrow!!!
