New to boating
oaklane2
Hello all,
New to boating and have a question regarding idle speed handling in my boat. I have a 19 ft Galaxy w/cuddy 3.0 liter Alpha One and at idle speed the boat "wanders" around, as I increase speed before the boat starts to plane the handling improves. Is this a trim issue with the outdrive? thank you for your input.
Nothing unusual. It's called wandering or hunting. Very common on smaller single engine boats. Just try not to compensate too much with counter steering. It is not a trim issue, but I've heard that if you trim out a little (gets the bow up a tad) it might help the movement a little.
no. It a hull design issue. There is not enough resistance to stabilize your propulsion. Speed helps alot but then you can run into the same thing on some boats with too much speed. Not enough boat in the water...:0)
When you at idle speed, you are probably in a No Wake Zone. As tempting as it might be to bring up the bow a little or increase throttle a bit to improve handling, those things also increase your wake. So don't do it in a No Wake Zone.
Some of the wandering can be controlled by turning the wheel back into the boat a little. It is common to over correct when driving the boat at idle. So turn a little, then wait to see if the boat tracks correctly or not prior to adjusting again. Remember your boat is influenced by current and wind, so it will never track perfectly.
http://www.uscgboating.org/safety/courses.htm
Course you could just buy a lot bigger boat! You know you want to!! Bigger boats, like twins, don't tend to do this wandering thing.
Also, outdrives with dual props don't wander as badly as single prop drives.
As noted here and above, the wandering is part of the game.
Try a double over a single mixed drink...3-4 doubles and you won't notice the wandering. ;)
(DISCLAIMER: THE DRINK PART OF THIS POST IS NOT INTENDED TO BE ADVICE. IF 3-4 DRINKS PUTS YOU UNDER THE TABLE, THEN TRY JUST A SIP AND SWITCH TO DIET COKE)
scott as to your answer does it mesan I needto pull the plug and let a little more boat in the water or wht.
well yes... that could work but no, don't go that route since I don't know what the bottom of your boat looks like.. I'm sure you will get use to your boat and will be able to handle it just fine. I do turn off my lower bilge pump on choppy days to stabilize the boat better but I do have a high water bilge pump. I would suggest you concider what your perfect boat might be for your next boat from what you would like to change from this boat. Forefoot also helps a boats ability to stay strait. Alot of the new designs don't have it.
It has to do with a lack of water passing the rudder (drive lower unit). As you speed up, more water passes the drive and it therefore has more rudder effect. Only a boat with a large rudder and/or a full keel doesnt have this problem.
I enjoy the wandering part of boating.... it makes people wonder where I'm actually headed!!
OAK-even my 28' with twin outdrives wanders at idle a little. Try driving the boat at idle with something like 2 fingers of one hand on the wheel. This will help you not to overcontrol at slow speeds. In a couple of months you won't even notice the wandering, unless you are using Mike's solution.
Heck, my 29' Searay Sundancer wandered like mad at idle speeds. (single engine)
The only (slight) improvement is to make sure the lower unit isn't trimmed all the way down. Get it either level with the surface of the water, or trimmed slightly up which will raise the bow very slightly.
It can be very annoying if you just want to troll at slow speeds. Can't be avoided though.
(My current boat has a keel, twin engines and weighs 10 tons. No more low speed wander ;)
Thanks all, I told MY Admiral we needed that 24 ft WAC w/ twin 150's, alas but some women just won't listen to sage advice. I particularly like the Msibley's advice I will try that the next time that I go out without my kids. I was kind of thinking that this was a new boat owner prank that was being played on me. It is kind of exasperating watching other boats in a channel running true and here I am zig zagging along. I'll just tell the Admiral that I need to get out more often and practice.
Then again, you can put two hulls in the water. Our kitty doesn't wander at all :D
