Replaced the transom in my boat this winter. Had to do the motor mounts, too. 260/merc alpha, circa 1985... I made a jig that sets the position of the front mounts using the rear engine mounts (transom housing is mounted on the transom). I know up/down will be adjusted with mount studs. My question is side to side, what is the proper procedure for locating the front mounts?
