Newbie needs advice
laramr
First time boat owner. So I'm in the dock and all wired up. What does everyone leave powered up and why? Different for the weekend when you'll be there and during the rest of the week when you won't? How often do I give in to my paranoia and drive over to make sure she's still afloat? All opinions welcome! Thanks.
Mike : We leave our batteries on plus our charger. We also leave our Fridg. and our air cond. on, however it is set on the humidity control. We are fortunate to live only 2 mi. from the marina, however I sometimes don't get down there for a week at a time.
Just make sure your bilge pump is working ok and the automatic float switch is free and clear. Then you don't worry about sinking. If you have propane on board, make sure it is turned off. More boats blow up late sunday night after a weekend becaue a propane fridge is left on and the tank leaks. If you are in tidal waters, make sure you left enough line to travel the max and minimum water levels and stay secured to the dock. Lastly, don't forget to lock your boat so it will be there when you return.
Happy boating.
I leave the AC in humidity mode, the fridge and the battery charger. Bilge pumps are always on.
try and get in the habbit of shutting your water pump off. I do and don't myself. I got lucky and remembered to shut it off a few weeks ago and good thing, the pressure gauge busted thus letting the accumulator pressure loose water, but at least the pump did not come back on and dump the entire 170 gallons plus burn itself up.
Probably the single most important thing to shut off when leaving is the dockside water spigot. This can sink a boat and has sunk many. Hopefully if you forgot and the regulator broke one of your neighbors or the marina would notice all the pumps were on and shut it off. On my boat I leave the AC mains on so my battery banks are always at full charge, my alarms, the frig, my wireless internet because I share it with my neighbors and the AC units are set to dehumidify. My marina watches my boat and I trust them with the keys. Take care. Bill
