Nice towing move
b_arrington
Coming back from fishing Tuesday night I saw some genius at work.
Approaching Port Jefferson harbor entrance (it was full dark) I saw a anchor light near the marker light. I figured it was a guy anchored fishing ( in a bad place). I got closer and saw it was an older ~22 foot express-type fishing boat. Suddenly a spot light from the boat lights up a PWC behind it.
There was a line going to the PWC, so I thought it was disabled. After watching it for a few minutes I realized the PWC was trying to tow the boat!
This struck me as really dumb on a number of levels. For one, as soon as the spot light turned off, that PWC really disappeared. They were also towing into the channel, and it was relatively busy (sail boat, rec fisherman, ferries). Having that single anchor light didn't help either.
I waited around for a few minutes to make sure there wasn't any immediate danger, but I wasn't going to offer to do any towing. I ended up putting out a Security call so no one would run them down.
What would you have done?
another stupid trick... it is illegal to run a PWC at night in many states, even if you add lights from what i read in FL regs for instance.
the securite call was a good move, but if the conditions were good and the distance short, i would have offered them a free tow into the habor. I know some will conveneintly cry LIABILITY! but i coudnlt' have gone to sleep that night if i had not at least offered.
done that a few times, no big deal, only takes a a few minutes
As Pascal mentioned, that's illegal use of a PWC after dark.
It's also a very very BAD idea to use a PWC's jet to tow a boat with. It grossly overstresses the pump and engine and will drastically shorten the life of the PWC. How do I know this so well? Heh, well I blew an engine on a Seadoo GTI after towing a stranded runabout in a few summers back. The dealer did replace the engine but told me to never tow anything larger than a person tubing/skiing as they just aren't built for it.
I wouldn't tow anything at night unless I had the blue light required to indicate a vessel being towed. I'd offer to call a tow service if they did not have a VHF radio or strongly suggest they do that them selves if their radio worked. I would advise them of the dangers and potential damages of proceeding as they were. If they chose to continue, I'd tell them to turn on their nav lights!
The Securite call was an excellent idea!
probably one of the first stories i have heard of a jet skier taking initiative and towing somebody...probably because nobody with a boat would do it.
i would have offered to take over the tow. there will be a day when i need the favor returned.
After watching the events, I got the impression the jet skier was a friend or relative, not just a random passer-by. I thought it was against regs to operate a PWC after dark; that's way I was so shocked to see it out there 45 minutes after dark.
That's a major reason I didn't want to provide a tow. I think they use an amber light (Sea Tow does in my harbor), and I only have the standard nav lights. I also think they would have been better off with their nav lights on.
I may be an anachronism, but I assume that if I'm on the water I have an obligation to lend assistance within the limits of my skills and equipment. Marine towing is expensive, and lots of nice folks on the water can't afford it (although most could afford a Boat US membership if they knew about it). Although I would have been sorely tempted to let them fry the jet-ski (one less buzzing mosquito in the world) I would have offered a tow. Even without the proper nav-lights it would have been a far safer operation than they were up to, and getting them home safe would have been a nice way to cap-off the day. However, I have no argument with those who wouldn't want to take it on -- there are many good reasons not to.
Robert
well you're only "obliged" to assist if someone is in danger.. where these clowns in danger ? not immediate...
LOL... blue lights are law enforcement only, not tow. that tow would require a second white masthead and a yellow light over the white stern light...
Why bother with lights since so few boaters know what they mean anyway... it's a lousy excuse for not assisting. Better have someone with navlights pulling the disabled vessel than a lightless jetski ! keep the line short and someone with a spotlight to light the line if needed.
I would have offered to tow them.
Hopefully, if needed, the favor would be returned some day.
The securite call was good, assuming people all had their radios on and were paying attention.
I had to tow my son's jet ski across the main channel at Lake of the Krazos, I mean Ozarks. We tied two lines together with a Sheetbend then a bowline knot for his jet ski. I was pleasantly surprised, as this was a weekend when those of us with brains don't take our boats out, when other boats screaming up the main channel gave us the right of way. We basically went the two miles at a smidgen above idle speed as I had never towed before and I didn'y want lines snapping or one of us going out of control. It worked just fine and the SeaDoo is now in the shop.
Pascal, I meant "obligated" in the sense of my personal approach to it all, not legally. I like to think that we have a sort of bond out there that is pretty much now totally lacking on the road -- and we all know that an apparently manageable problem on the water can turn bad pretty quickly given the wrong combination of circumstances.
Robert
The PWC, if he proceeds at a slow rate, can tow the other larger boat. I see PascalG sure picked up on the blue light thing, I sure did! Port Jeff is not the best harbor to be towing into though. The larger disabled boat should have had a light illuminating the PWC along with his running lights. Sometimes we have to adjust to the situation at hand. Sure, the PWC shouldn't have been operating after sundown, but he was likely just helping out. Better to have some help as opposed to meeting those rocks at Port Jeff's entrance. I hope the disabled boat got in safe.
robert, i agree with you 200% and feel the same way. my point was simply that one is only legally obligated to assist in case someone's life is in danger. unfortunately, too many are too quick to find excuses not to help a fellow boater
Uh lets see, we have the excuse of not using the jetski to tow because of the "danger" without any accomodation of the fact that "danger" already existed merely because these folks were drifting in a disabled boat after dark.
That's where I stop listening to most of the "danger" arguments.
Calling security was top notch though.
bp
I don't see what the problem is, the regs kind of go out the window when there is a vessel in need. The fact that they didn't have the right lights was over come with the use of the spot light, I've done the same thing several times over the years, in fact just the other night with the marina work boat, all I had was a spot light. What the regs really say is this is the way things should work, if for some reason these can't be followed do everything you can to avoid a collision, and let the other boaters in the area know your intentions or what is going on well in advance.
I doubt that towing with a jet ski is any harder on it, in fact it has to be much easier on it than jumping waves.
Just remember, if you tow you also may assume full liability for any subsequent damages, or a collision.
The law is also very clear on the lighting required when performing a tow. Ignore it and you may well end up paying a huge price for your ignorance.
ok... so i guess by the same token you never give friends a ride on your boat or in your car... you never help anyone... heck... hold that door for an old lady and if she slips while you are holding the door, you could be responsible.
very sad.
Agree with Pascal... I'd have offered to help, and if refused I'd probably have stuck around just in case. Wouldn't be the first one I've dragged in...
Adrift, I think as long as he's lending assistance to a disabled vessel he's not reqired to have the proper tow lighting. Not too many pleasure boats on the waterway meet those requirments. It's a totally different story for a commercial tow. If you tow someone and charge them for your services, you'd better have the proper lighting and a Captains License with a towing endorsement. Also make sure your tow boat does not exceed 26ft. An additional endorsement is required then. As for the liability factor, if you've done due diligence and thru means beyond your control, there is damage, I'm sure an arbritrator will make the right call. I've towed many disabled vessels to safe harbor and I hope when I need help, a fellow boater will lend a hand. I also belong to SeaTow/Yellow boats and TowBoat/US, the Red boats. Cheap insurance when the Marine Assistance Request Broadcast goes out.
