NMEA 2000 Question?
Putting together Garmin NMEA 2000 backbone and was wondering about compatibility with other manufactures NMEA 2000 sensors? I know all the fine print say it should be compatible but I have found out with other projects that's not always the case. Also is there a third party who make sensors and a “black box" interface which can hookup say switches and analog temperature sensors and covert he the data into NMEA 2000 statement for the data bus so it could be read by the display?
I found some information on SeaGauge-Remote N2K is a multi-function digital marine gauge that replaces mechanical instruments and gauges in marine and boat electronics applications. Seems to do what I want to do such as TACHOMETER, RPM, OIL PRESSURE, ENGINE TEMPERATURE, FUEL LEVEL, VOLTMETER, MAIN and AUXILIARY BATTERY. Seems there should be a market for this kind of equipment. I saw somewhere a converter to move NMEA 2000 data from the bus to a USB port for a laptop and software on the laptop to display and interpret the data correctly.
Has anyone tried this product of any other with similar functionality product? Or is it too much cost and hassle and not worth the effort for the results?
