NMEA 2000
seeray96
Anyone know of a site where I can familiarize myself with this standard? Also, I'm finding it very difficult to find a dealer that sells the necessary cabling, T's, etc. Some of the marine electronics companies'
are absolutely useless in this regard. They advertise NMEA 2000 compatibility for their equipment, but neither list nor recommend appropriate network cabling and fittings.
Here is a start for you.
http://www.nmea.org/pub/2000/index.html
As I understand it, the manufacturers are supposed to have a standard for fittings so you can connect an X radar to overlay a Y gps and connect to a Z radio with a man overboard button.
I have never seen it done as most electronics installs I have seen bought as bundles.
It wasn't until last year that the cabling connectors were standardized (or shipping that way at least). But the internal wiring is the same on all of them. Splice the wires from a Lowrance blue connector to a Raymarine SeaTalk2 and it works fine. Likewise for other brands. Currently manufacturer gear (not left over old stock) is likely to be using more standard connectors. But even if they're not it's trivial to splice them as needed, I know, I've done it for three different brands of gear all on my boat's NMEA2k network.
I appreciate the info, guys. From what I've read, I assume the blue connectors are for the heavier cabling. Can the blue connector drops be mixed red and vice versa? Or is the network either all red or all blue?
Lowrance came out with the blue connectors prior to the standardized connector. It was what they thought it would be. I think some of the other companies are just using black or metal. The red ones from Lowrance are now what they are selling to match up to the standardized connector. There are adaptors that will allow you to connect a blue one to a red one.
Lowrance has a system builder on their website that will allow you to play with the connections and build the backbone configuration you want. They also have a pretty good explanation on how the systems work.
