Quick brief on GPS <--> computer communications:
The computer sends what amounts to a request for info ( via a type of serial communications line ) to the GPS. The GPS who ( we hope ) has the answer to the question, sends back an answer in a special format.
If you ask the wrong question, you get no answer.
If you speak the wrong language, you get no answer. ( It likely wants: "NMEA 0183" )
The serial line ( hardware wiring and it's connectors ) must be working correctly, at the correct speed.
In short, there are several places where there is an opportunity for a problem, but in many cases, the "default" is correct. You will need to, for each unit, check that these things are set correctly ( or at least, in agreement! Wrong might actually work. )
Since you have checked the cerial protocol numbers and gotten them in agreement, make sure that the Nobeltec is sending the right command codes and reading the correct incoming language. But since I haven't used the Nobeltec stuff in years, I have no specific instructions for you. Sorry...
