non-orbital or orbital buffer for waxing?
kmont97
I have a midnight blue hull and have always polished and waxed by hand. I use a polish first then wax after. What tool would you recommend for both procedures? An orbital or non-orbitsl buffer? Any manufacturer recommendations are welcomed. Thanks in advance.
Rotary buffer for polish. Wax by hand or orbital buffer. I don't use "wax" anymore though.
Take a look at the Makita BO6040 polisher.
"Makita makes the BO6040 Dual-Action Polisher, an ingenious polisher that works as a circular polisher or a dual-action polisher.
An orange knob on the Makita Polisher makes it possible to switch back and forth between dual-action and circular motion. Just be sure the machine is off when you make the switch. The speed control on the back of the machine allows you to operate at anywhere from 1600 to 5800 opm, no matter what mode you are in. Use the dual-action mode for gentle polish and wax application, and buffing. Use the circular motion for compounding and scratch removal. One machine does it all!
Best of all, when the Makita BO6040 is in circular mode, it still jiggles like the dual-action motion. This lessens the risk of producing swirls while still giving you the cutting power of a circular polisher. You should still take great care when operating the machine in the circular setting by starting at a low speed. We recommend 2 opm until you are more comfortable.
The Makita BO6040 comes with a one year factory warranty and a handy carrying case. It also comes with a wrench to remove the included 6” Hook & Loop backing plate.
The Makita BO6040 replaces two machines, making a great value. If you do not currently own a buffer, or you are not sure if your vehicle’s scratches will come out with an ordinary dual-action polisher, this is an excellent choice. Start out with the dual-action setting and a low-cut polish. The general rule is if your fingernail catches the scratch, you’ll need to do some compounding to totally remove it. If the dual-action is not working, just turn the machine off, turn the orange knob, and turn the polisher back on. The forced circular motion will cut the scratch down until it is completely eliminated."
I agree with Gregory on the not using wax any more thing. I like Zaino. But others like Pro Polish. They seem to be very simular in how well they work and last. Which is very good and very long.
That looks like something worth checking out. The pro I used had a Makita but I don't know what model.
My efforts with an orbital polisher produced pretty poor results.
