I run a 7.4 mpi I/O and usually use Pennzoil straight 30 weight. I went out today and bought some and after I got home I was reading the label in smaller print says 4 stroke motor oil. Is this the same as regular 3o weight? Thanks
There are 2 stroke engines and 4 stroke engines. If your oil also says 30w, you have the right oil.
Almost all inboard engines (which includes I/O's) are 4 stroke. Your 7.4 is definitely a 4 stroke engine.
