oil
Gregory S
Well-known member
I usually use Mercruiser 25/40 oil. I'm now told by a local dealer that Merc no longer markets the straight dino oil and are selling what they call a synthetic "blend" 25/40. I've seen the bottle and ays it's a blend of mineral and synthetic oil. Anybody heard of this? I've been shying away from synthetic oil in my '94 454 Crusaders.
+This is an offshoot from automotive oils. Supposedly the "blending" contributes to stability under pressure and temps and provides a somewhat longer useful life. I suspect it is merely another way to part a man from his money.
Thanks Bill. Should I be concerned about going to this type of oil after 650 hrs?
Synthetic oil starts with the same crude oil as regular oil. The difference is that with synthetic, the carbon chains that make up the oil are broken apart and then put back together in a more consistent pattern than they occur naturally, thereby increasing the stability of the finished product. There are no ill effects (except cost) from using synthetic oil, regardless of the situation. Blending synthetic and regular oils improves the stability of the product for a lower cost than pure synthetic. Keeping the oil changed regularly will do more good than spending more on the oil itself.
We've heard on this and other forums many times about the possibility of developing leaks when converting to synthetic oil in older engines. That's my concern here.
Actually Synthetic oils are not typically made from crude oils. They are made by chemically combining carbon dioxide, carbon monoxide and methane using a process developed in Germany during ww2 called the Fisher-Tropsch process. Another way of making the synthetic is using the Bitumen from the tar pits in Alberta, Canada. A third way is the conversion of polyesters or diesters.
Since they start with essentially pure ingredients, the resultant oil polymeric chains can be developed with uniform length and identical chemical character
Still no answer to the oritinal questions though. Anybody heard that st dino Merc 25/40 no longer made? Should I be concerned about a synthetic "blend" in engines with over 600 hrs?
Greg--
This whole argument was made within the various Car CLubs , perhaps five years ago. Folks with ancient and costly cars were interested as were the folks on the drag strips. There should be no concern about changing to part syn or full syn if you have a well maintained enhgine at the moment. I know of no harm in changing, nor do I have any way of reckoning that my use of synthetic in a vintage Mercedes did me any particular good. Oil change frequency is the true key to longevity. Most all oils that you might consider have adequate additive packages for whatever 99.99% of us do with our engines. Aero, Nautical, or Pickup truck.
SHELL ROTELLA, and MOBILE 1 were the Gold Standard when I last became involved in this chat.
Actually Mike, most oil producers (Mobil, Chevron) use the Hydrocracked/Hydroisomerized method for producing synthetics, due to the high cost (10 times as much) of the Fisher-Tropsch process. Crude oil or, as you mentioned, tar sands are the base products for this process.
