Outboard Props
mixman
Livin' the life.
It's time for some new props on our boat, a 30' power catamaran with twin Honad 50 outboards. I've played around some over the past few years with 3-blade vs. 4-blade and had settle the last 2 seasons with ProPulse composite props with adjustable pitch. I had to over-pitch them to get what I wanted, which only got me my claimed 17 knot cruise in perfect conditions. And while the idea of being able to replace a blade when it breaks is neat, it's also rather annoying when it happens every other day, which it just did on our recent cruise. When we got to Great Sale in early May the Admiral asked me if I had any other props onboard. I dug out the old original Honda props for the rest of the trip and wow, much better performance (cruise of 16 knots in slop, 17-18 in calm). I would just by another set of these exact props, but Honda states that they want to see WOT as close to 6,000 RPM as possible, and at least over 5,000. We cruise with the original Honda 11-1/4 x 13 props at 4,900 rpm, but can only get WOT to about 5,100 rpm. So I thought I'd try dropping the pitch down to 12. I went to the local marine box store (so I could return if they didn't work) and ended up with Mercury 10-5/8x12's. We can now get up to 6,000 RPM at WOT, by I have to run at 5,500 RPM just to get to 16 knots (believe it or not Honda says the engines can cruise anywhere below redline without damage...but yes, that's too high for my tastes). I thought dropping 1" in pitch would only gain 200 RPM. So how did I gain almost 1,000? Any suggestions for what size prop to try next?
The new props have a smaller diameter as well so don't move as much water. EITHER reducing pitch OR diameter will increase the rpm... you did both.
Find a full-service prop shop and talk to them. Within reason they can probably adjust the pitch OR the diameter of your old props. You might be able to take the new props back.
Thanks Willie. I thought the diameter would add to the slow down issue, but you confirmed it. I'll try and research local prop shops here in MD, but most people up here just don't understand catamarans. Where's Bob Austin when you need him?!!?!?! Bob? Bob? Where are you? :-)
There are many attributes of a propeller which will change the performance of the boat. Diameter and pitch are the most obvious. However, the are also cup, rake, diameter/area ratio (DAR), number of blades, thickness of blades, material stiffness and the shape of the individual blades. One attribute commonly ignored is damage. Like I didn't hit the bottom very hard and it doesn't vibrate too much. It can kill performance.
David Gerr's "Propeller Handbook" is a good source of information for a tiny fraction of the cost of your next set of props.
I will have to try and find a copy of that boat.
Anybody have an idea what I can expect if I keep the same size but switch to stainless instead of aluminum?
