Penn Yan
jeffreytcole
Now that we have stepped away from the Carver, we have found a boat that meets our needs a little more. We have looked at an older Penn Yan sportsfisher 26'.
Does anyone have any knowledge of this model or experience with the now defunct Penn Yan manufacturer.
I know they were big in the great lakes region for a while then moved production to North Carolina where they soon went out of business.
Jeff
They are still popular boats in my area particularly since we are only a few miles from the original factory. Over the years, they had issues here and there like any other boat. I recall back in the 70's they had a problem with the cockpit floors and recalled all the boats involved and installed new ones.
I owned one new one, a 21' with an I/O. It was a solid boat, very plain and built for fishing. I would have preferred a larger, tunnel drive at the time but could not afford one. A local marina recently sold a used 26', twin engine tunnel drive. I looked at the boat, very solid and still very good looking.
We have 3 24 footer's in our club. All are mid to late 80's and I/O's. I know all these guys and they don't have any problems with them. I spent many hours on Lake Erie in a '88 hardtop fishing. That boat was bought new by a freind and had no real problems the 7 or so years he owned it.
Good luck
Niles
USCG had a fleet of them in the mid-late 1970s if I recall, maybe a few years later. I was involved in the retirement of the last of them in the early 1990s. They sure worked for shallow water running and given extremely hard use they lasted well. I'd venture that one operated respectfully and maitained carefully [to keep water out of stringers] would still be a good boat. The last ones we had were all soft inside. I remember one sitting on the trailer. You could grab the edge of the deck at the bow and twist, the stern wouldn't move. We had reserve volunteers wanting to gut it and rebuild the structure but couldn't get approval.
beware of a tunnel drive if its a deep tunnel they are noisey and very inefficiant they are easy to spot on the water as they throw a huge wake behind the boat they also tend to wander at slow speeds. there used to be many around here but almost all are gone now it won awards around here as the worst boat for fishing
tugboat kevin, do you have any experience with a Penn Yan? Didn't think so...
The tunnel's are not really noisy, but a lot of guys don't like them because they are inboard and the small boat guys embarass themselves at the dock since they don't know how to run them.
Great boats. Don't underpower them. Do a thorough survey, and check thoroughly for rot in the stringers and transom.
bp
Penn Yan is George's personal boat, perhaps he will chime in here if you send him an email or post a question on the Engines forum.
Had a mid 70's, 26 footer, w/ Chrysler engine. Really loved the boat, but continued to have problems with the engine. Very stable. No problem w/ tunnel drive. Close quarter manouvers no different than any other small boat w/ rudder.
very knowlageable on these tunnels the later generations with the quarter tunnels work well but the full tunnels on the older ones really throw a mushroom wake and use a lot of power running more like a jet boat than a inboard the noise comes from the top of the tunnel its very distinctive i even own a couple want one to fix up? will just about give it away!
I don’t know of many 26’ers with a 10’ beam, straight inboard, large flat open cockpit, and 20” draft.
I have a 30’ Penn that is like a rock, and love it for what I like to use it for. I also have a 26’ Robalo with twin outboards and I can’t take it in the coves and flats where I take the 30’ Penn.
As others have said make sure the stringers and transom are good.
I don’t think you will find many Penn Yan owners or previous owners that speak badly of Penn Yan.
