I added a dual voltage 120 volt and 12/24 volt norcold de0740 to my boat this weekend. Silverton uses this exact model in the same location when it is optioned out on the 45c. I installed it and it works but here is the problem (background first). Silverton so nicely prewired it irrespective of whether or not the option is actually ordered with the boat. On my breaker they have a 12 volt switch pre labeled cockpit refridge and there is an existing red wire connected to it which is for the indicator light that goes on and off when the switch is turned on and off. Here is the problem, once I connect the hot for the 12 volt side of the fridge with the master 12 volt switch on for that "group" of breakers on the panel, the light turns on even if the switch is in the off position. I don't know if the wiring for the 120 has anything to do with it, but the boat is not even plugged into shore power yet. With the fridge powered on via the knob on the fridge and I switch on and off the breaker the light will light up and dim (but not go completely off). With the power on the dial on the fridge switched OFF, sliding the breaker on and off makes far less difference in the intensity of the indicator light on the breaker. I checked all of the other connections, everything is tight. I even switched it to a different breaker switch in the same group and it did the same thing. In fact, if you can imagine the "master 12 volt" switch for the group of breakers in the on position but all other switches "under" that in the off position, as soon as I touch the red 12 volt positive wire to the pole on the breaker in the off position, then the indicator light lights up
Oh.. this MIGHT be important. There is an existing outlet for the icemaker next to this fridge position. I was afraid just plugging it into the icemaker circuit might cause breaker for the icememaker to trip if both kick on at the same time. I went to the hardware store to see if an outlet existed to wire two 120 volt separate circuits into 1 outlet and the guy at the hardware store said I could do the same effective think by breaking the metal bridge between the two outlets on the same 2 outlet affair. I took my needle nose and twisted it until it snapped off. I then wired 120 hot, negative and ground to one outlet side and the other hot, negative to the other side and shared the ground with the other ground. 1) This seems real dangerous in retrospect, 2) could it be effecting what is going on on the 12 volt side??
Help!
Help!
