- Jan 1, 2000
- 385
- 2,884
Ok, it's done and it is very cool. I installed a Camco Torando flusher with a deck fitting. Here is what I did.
Take the Camco Torando flush model 40128
NOW, you could screw the flange straight to the tank, but the holes and the flange might crack your tank. What you need is a good renforcment. So buy this kit, Dometic #307348685.
You have to grind off the "bumps" on the bottom of the plug with a Dremel tool or something similar. Then drill a hole in it and install the Tornado flush on the plug. That way if the flusher breaks, it is easy to screw the plug out and replace it. The finished installation looks like this. (Note you also have a very nice sized "access port" in your tank now.)
Next get an ITT Jabsco deck fitting for deck washdown. The unit looks like this.
Remove the check valve from the "plug" (the black plastic male fitting). It comes out real easy, practically falls out in reality. This is because you are going to make the water go the other way. The deck fitting (the metal part has a check valve in it so no odor will escape)
Install the deck fitting:
Go to a hardware store get a "male-to-male" garden hose connector an attach it to the insert fitting. Then connect up a hose and flush the "shiite" right out of your tank as you empty it.
Here it is with the hose attached. Note I mounted it close to the pump out fitting.
I have tried the unit out and it works great! The toughest part of installation is drilling the big hole in your tank for the Dometic access port (and smelly too). Get a hole saw of the proper size. Do not try to free hand a circle because you will create stress point in the plastic if you do not create a good quality round hole.
