Poor results with Seamark & 303?
SLW
My canvas enclosure has Sunbrella Seamark (vinyl coated canvas) on the top, as did the circa '96 OEM enclosure. The OEM enclosure lasted 9 seasons. At that point the fabric side curtains and the Seamark top had shrunk, zippers were breaking, stitching was letting go, but the coating of the Seamark itself was still intact. I cleaned it with soap and water and sometimes even used the spray setting on a power washer. I also occasionally needed to use diluted bleach to remove stains. I treated it every once in a while with Armour All.
By the time the whole enclosure was replaced, I had banned Armour All from the boat and was solidly in the 303 camp. The new set of canvas has been treated with 303 Fabric Guard and the inside of the Seamark has received regular applications (apx 3x / year) of 303 Protectant.
This enclosure is now 7 years old. The canvas panels are in excellent condition, but the Seamark, which has been supposedly treated with much more care than the stuff it replaced, is about to give it up! It has not only shrunk considerably, but small tears in the vinyl covers both panels and the sections feel stiff and brittle - as if they're cold and dirty. (neither of which is the case)
I noticed as I was applying the most recent round of 303 that it acts, looks and smells very much like it's "evil twin" Armour All. Now that I see that I will have to replace the gently-treated sections in less time than I did the original, neglected panels, I have to wonder: is 303 more hype than help, or did Sunbrella quality go down?
Has anyone else experienced this?
IMO, 303 is 10X better than Armor All. The only thing I dislike about the Seamark is it doesn't breathe like the uncoated Sunbrella & as a result develops mildew on underside of bimini top. Probably wouldn't happen if it was just a bimini top w/o a full enclosure. Diluted bleach easily removes but never had to do prior to the Seamark. One advantage to the Seamark; never have to spray canvas side with 303 Fabric Guard.
303 is good, but it takes several applications per year. Especially if you are way down South.
Nothing is perfect on fabric. In my opinion, fabric takes a lot of care.
So what convinced you guys? I learned of 303 from this and other forums. My actual experience is contrary to my expectations, but it wasn't exactly a scientific test.
I hope to get a few more years out of this material, so I think I WILL conduct an experiment and leave some of it untreated as a control.
Seamark is a great product. Starting my 8th season, and all enclosure pieces still look like the day I bought the boat. Cockpit cover gets thrown in the washing machine, treated with 303 fabric guard, and never looked better.
I have never done anything to the inside surface, other than wipe them off. Never had any mold issues, or dirt.
Not sure what you are doing wrong.
I am told that Seamark must have ventilation, because it cannot breathe.
Try talking to the manufacturer, and let us know the results.
7 years in FL is better than normal. Under wraps in the north I would guess much longer.
