2003 Volvo 5.7 GI Port side Turn the key and all I get is a click in the ignition relay that is located in the fuse box on top of the motor. Pulled the relay put it back in and the motor started. The next time I tried to start,nothing, just a click at the relay. Swapped out the relay from the starboard motor and both motors started fine. After 3-4 starts on the port motor, it will only click again at the relay. Starboard motor has been starting every time with the original port relay. So I do not think its the relay. Battery is strong. Sifter is in nuteral. Could the fuse box gone bad? Not sure where else to look. Thanks for your help.
Turned out to be the fuse/relay box on top of the motor. But I now also have good clean connections at the starter, engine ground and battery, Thanks for all the advise.
