Today I tried to update the software from 2.50 to 2.70 on my Garmin 4008 chart plotter. Downloading of the software to the SD card was reported successful. I started the chart plotter and inserted the SD card. I did then choose "update software". A horizontal column appeared and showed progress together with some messages. After the column had reached the end, the chart plotter performed a reset, and came up again with "Loading software". Then nothing seemed to happen. I waited several minutes (perhaps not long enough) and then turned the unit off and on again.
After that, the plotter seems to work normal, except that the only button that works is the on/off button. It still reports software version 2.50. When I insert the SD card with the update, the plotter comes up with software update as an alternative, but I am not able to choose this since the buttons do not work.
Does anyone know what can I do to get the plotter to work again?
Best regards from
Jens
Best regards from
Jens
