About 3 - 4 weeks ago I rebedded 3 windows on my boat. I used 3M 4200 which cost me damn near $20 bucks per tube. Nevertheless, on 2 out of the 3 windows, the sealant has actually pulled away from the window causing them to leak. Usually with bedding adhesive, one would screw the window in say 85% of the way, let the sealant dry, then tighten the screws then rest of the way. This method can't be used on this style window though. The way these windows are designed, they bolt in from the inside and then on the outside the sealant is just applied between the window and the outer trim ring.
Has anyone ever experienced this? Is it possible that the tube of sealant was sitting on the shelf for a while and has gone bad?
I resorted to regular silicone caulk on one window as a test this evening. Will it last since it's above the water line? Buy a new tube of 3M 4200 and redo them all again?
Any advice would be great. Thanks again.
Doug
Doug
