David- Ever since Dave Gerr wrote the April Fool's Day edition "Holey Props"article for Offshore Magazine about the technique of drilling holes in the blades of props for best efficiency, he has been one of my heroes. I don't think we are disagreeing and I have no expertise , just have talked to the head techs at a couple of the major interstate NE prop shops for hours about prop theory, design, & service , etc and have enjoyed a # of Gerr's great articles but haven't yet secured a copy of his legendary prop book. Of course I've forgotten 90%+ of what we had a lot of fun discussing, and the age thing isn't helping there.
The vibration attenuation wedge and hole setup can easily be done as a retrofit , as this is the way it has been applied in all the cases I've heard of around MV , Woods Hole and Nantucket, but personally I would not attempt this on a relatively speedy planing boat like your Sundancer or my Phoenix . I'm not sure the prop would be safe from ventilation in that case but who knows, but the bigger props of the slower downeast diesel boats have the greatest impact on the hull and resulting annoyance. I frequently am onboard a friend's Northern Bay 36 FB which now has this setup with the air source holes flush with the sole next to the transom . ( This is a 17kt boat, I'm not sure how well this would work on an 8kt boat, as the effect kicks in on this one at maybe 10-12?kts. with the thin wedge he uses.) Underway, if I walk back there and place my boatshoes over the holes, the really annoying/exhausting loud vibration (that we had always originally attributed to generic expected diesel engine vibe) would return in full force within seconds as that air cushion was expended. When I clear the air supply once again (& as long as they are open (above the critical speed ), the vibes would quickly( few seconds) decrease by at least 2/3 or more & I gather that has been the general consensus of owner's who have tried this. I think I've heard of people using fiberglass, PVC or vinyl strip as material for the simple wedges-anything that creates that slight low-pressure area will work to draw down the air and spread it slightly laterally above the prop. Even in hard reverse, I've never seen water come up through the air holes in the cockpit sole.
I think I have 3 pics I took of the NB36's wedge & holes I can e-mail you if you send me your e-mail address. I don't think I can attach them to e-mail through the B/Ed link. Not sure how visible the setup is but you can post them if you want.
