Proper Anchoring Procedure...
BoatMan123
While I've been boating for quite awhile, I've very seldom anchored. I'll have a new boat this season with a windlass. Can anyone describe the proper anchoring procedure using a windlass?
Not too much different than without one. Bow into the wind if you can. Lower the anchor letting out 7:1 scope. Depending on your anchor and bottom, you may need to back down on the anchor to set it.
When retrieving, pull forward while letting the windlass retrieve the rode as you motor forward. Don't use the windlass to pull the boat to the anchor. It's not designed to do that. Use your engines to get directly over the anchor and then use the windlass to lift the anchor.
Technique is only part of this equation. Your anchor and gear is a big part. I switched from a Danforth to a fortress and let me tell you, the fortress is great. It sets fast, it holds well and is easy to retrieve. The Danforth was heavy, never set well and dragged. The amount of chain helps alot too.
And if your anchoring overnight or for any lenght of time, use a snubber to take the strain off your windlass and to add some give to your rode/chain if the wind should come up.
If you are going to power down the anchor, then let it drop a little out of the bow roller and hang ready to deploy.
Never, just toss out the anchor.(it may tangle the chain and rode) Set it on the bottom and slowly back or drift off to about 1/2 of the expected scope. Stop and let the shank settle, give the rode a tug or a few, this will help the anchor to set. Back off to the intended scope, give a few more tugs. When you feel secure, tie it off and set the snubbers. Having a trip line will also help with retrieval.7:1 scope may be OK, it may not be enough. In a crowded anchorage there may not be room! Let the weather and tide conditions decide. I like to have a Danforth and a CQR both available and use according to bottom conditions.
Capt. Bill1, not to disagree with you, but would it make sense to cleat off the anchor rode to take the strain off of the windlass. We were told to do that years ago and I always cleated when we camped. With our 48, we have 100% chain. There is a rode lock that is flipped down to relieve the wave action strain on the windless.
missnmoutains. Capt.Bill1 has suggested a snubber and that is correct for several reasons. First, the snubber, which attatches to the chain with a chain hook or the rode with a rolling hitch, is a slightly lighter line, which takes up the shock which may occur with increased wind and wave conditions. The snubber also takes the chafe, avoiding any chafe on the primary rode. Snubbers give 25 to 30 feet of elastic line which takes up the shock.
Although you are correct that it is proper to cleat a line rode off, rather than leave it on the windlass, the snubber is better (it is also cleated). It is not a good idea to use a chain stopper. There is no give. When the wind really blows up the chain will be bar tight, and can break in increased wave conditions. I actually had an experience where a smaller boat than mine, anchored along side, and secured the chain with a chain stopper. I had a boat which displaced 50% more, and had the same size HT chain, but used a 25 foot nylon line snubber. When a set of waves came in, on top of the wind, his chain broke. My rapidly passing him a line and his engine work, saved his boat. If it had happened after dark, he probably would have lost the boat. Also usually the chain stoppers are not properly backed and can either tear out or break the fasterners. I will usually back my foreward cleats or sampson posts with large 3/8" aluminum plates to spread out the load of thru bolted fittings. If you look at the chain stoppers on large vessels, they are massive and have sets of springs to help with the shock load.
I agree a snubber would soften the wave action. The snubber and cleating together would be a best combo. I do have a question (I appologize if I am hijacking this thread). How do you get a snubber on anchor rode (assuming it is line and not chain) My dockline snubbers must be fed along the line. I am not aware of any that can be installed partially up a line without feeding them from somesort of an end such as the bitter end attached in the anchor locker.
You don't really need a snubber with an anchor line. I guess I should have left out the rode part on my rode/chain reply. The anchor line acts as it's own snubber. And you should tie the anchor line off on a cleat.
We talked about scope the other day aboard a boat with an all-chain rode. Do those of you with all chain use a shorter scope than customary with rope (and only a short chain), say 5:1 instead of the customary 7:1?
let me throw a different twist and see what everyone thinks. If I anchor and think their might be a chance of rough weather. I take a mushroom anchor I keep in a locker and using a quick link like a caribiner I conect it directly to the main anchor line and let it slide down the line say 20 or 30 feet or as far as it will go. I then cleat off that small achor line to a cleat. the main anchor line is conected to the cleat that is part of the windless on top.
the small mushroom anchor acts like a shock absorber. much like the snubber idea. when the wind or waves pull hard on the line it slowly lifts the mushroom off the bottom. I also believe it might help reset the mainanchor if it comes loose by keeping the line or chain near the bottom as it drags. Also the mushroom tends to keep the boat in a smaller swing arc with light wind.
like I said just my ideas and no fact. I think I might have seen it somewhere but have no idea what this method would be called if any.
if i am in close quarters, i will use less than 7:1 with all chain but if have swinging room, no... 7:1 doesn't hurt if the wind picks up. i crowded anchorages, i sometimes set wit 7:1 and then shorten the scope to 5:1 or even 4:1 if conditions are calm and there is really no room
i rarely use snubbers because i really dont anchor in exposed area. up to 25kts, 7:1 all chain will still provide some catenary effect to dampen the gust. Overnight, i do cleat the chain on the closest cleat.
I usually power down the chain instead of letting it drop. The last 5 or 10 feet I let it drop. And don't forget to put the boat in park.
Art
is that after you set the parking brake?
I started using a snubber right after we got our first boat with all chain, but for the wrong reason not safety
I couldn’t sleep with the chain shifting in the rollers while we swung, especially when the master was forward, so I started using a snubber anytime we overnight on the hook
Let me throw in another variable here. What do you do when anchoring out for storm conditions and want to use two anchors? AFter you set the first primary anchor how do you then "set" the second anchor? In my case the primary anchor will be a plow with probably all chain. I will probably be anchoring in 10 ft or so water and have 125' of chain.
G
this is why i'm a firm believer in oversized ground tackle: so that using a second anchor is truly a last resort! a second anchor is great to reduce swing (bahamian mooring) but you increase the risks of tangling rodes and shoudl you need to leave in a hurry (other boat dragging onto you) it will take twice a long to get going.
In the situation I am talking about there will be NOBODY on sny of the boats.
G
Anchoring is one of those things that I had a hard time with, until I realized what I was doing wrong...the right scope is critical to getting it to drag.
"like I said just my ideas and no fact. I think I might have seen it somewhere but have no idea what this method would be called if any."
That is an old tried and true method of "snubbing" your rode. You can buy a weight made just for doing that. It's called a kellet as I recall.
"AFter you set the first primary anchor how do you then "set" the second anchor?"
Just motor over on an angle forward but away from the first anchor, drop the second with short scope, set it and then let out more scope till you have out about the same as the first. If it's something like a hurricane where you would be leaving the boat, they make a large swivel with plates on each end that you can attach three anchor rodes/chains on one side and then run three lines to your boat from the plate on the other side of the swivel. Might be worth a look.
