Protecting Isenglass...
JeffreyCooper
Folks - I just sprung for all brand new canvas and isenglass and I want to protect it (particularly the isenglass).
I'd seem some boats around with some 'fuzzy stuff' (highly technical marine-term, I know) wrapped around the camper-top uprights (the bows). Seems like this might be a good investment to keep the metal from cookin' the glass...however, I don't know what it's called, and can't find it on BoatFIX... Can someone give me a name for the stuff, or a pointer to the appropriate link?
Also - alternate/other suggestions would be VERY welcome! We all know how expensive this stuff is!
the canvas shop should be able to get you the stuff. I also roll clean towels in the indows when I roll them up.
Excellent suggestion...
...only, my "canvas shop" is the OEM (Cruisers). Don't know if they have it. Don't even know what it's called!
go to http://www.westmarine.com/webapp/wc...e&storeNum=null&subdeptNum=null&classNum=null
I couldn't find the product on Boatfix but it may be there under another name. These work but it may take several in a particular area to keep the isenglass (strata glass) away from the tubing.
This week I'm putting all new canvas/strata glass on my 3 year old Regal 4260. The FL sun took a dramatic toll but I believe that a
portion of the problem was my own. Various detailers have used everything from Lemon Pledge to Simple Green on it in an effort to keep it clean and shiny. This never happened when I did it and always used products designed for use on it. On my boat it is IMPOSSIBLE to keep something in between the layers when rolling the stuff or to always put it up dry. That simply can't happen. When cruising the dew alone can be wiped off but the strata glass is still damp. This is bad but the wrong cleaners used on it are worse.
I'm not about to do all the polishing and detailing myself but I am going to make sure I supervise better and not allow anything other than the proper cleaning/polishing stuff to be used. We gotta remember that if these guys/gals doing the detailing were the brightest bulbs they wouldn't be doing this kind of work. When they're done it looks great but in a few days the cloudiness begins.
Bob's comments about the clean towels is absolutely what the manufacturer recommends, it's just not practical on my boat.
Good luck,
Mike, Palm Coast, FL '04 Regal 4260
Save yourself some money and buy the black foam pipe insulation you can get at Lowes or Home Depot. Likewise, use 303 Protectant on your Isenglass to keep it looking new.
We used to lay them down on each other with a sheet in between then roll them up and put them in a sack for the winter.
Use the P200 (?) spray before laying up and use it regularly to keep them clean.
By the way, the name of the fuzzy deals is Sun Sox.
We also use them for anti-chafe onthe lines.
PS. Can someone delete the long link that stretches this into LOOONNNGGGGG LINESSSSS?
Instead of towels which are heavy and bulky, we use a very light soft fleece, some boaters use felt pieces. Either can be bought at your local fabric shop by the yard. These materials are lint free, and do not require any seaming, just cut to size. You can get info about maintaining strataglass from Strataglass on their web site. I believe if you do not use IMAR products on new Strataglass, warranties are not in effect. We have EZY2CY and Strataglass on our boat. Because of the expense of these materials, I follow what they say on their company websites because if there are any problems, the warranty should be honored. Strataglass has been known to work with a canvas to company to replace a problem product. Unfortunately, I do spend a lot of time keeping up my clear vinyls.
BTW, Eisenglass is not the correct term. Eisenglass is actually a form of mica that once upon a time was used for windows on ovens and is very brittle. Clear Vinyls are what is used on boats, but many refer to them as eisenglass.
Easter,
You're dead right. Isinglass is the stuff you used to look through to see how your toast was doing in the mica lined toaster or how your
stuff in the oven was doing. It was transparent and could take the heat. But, old folks like me still remember stuff like that,
the time before TV and hamburger at three pounds for a dollar. Hell, I was even DRAFTED into the Army. Before Vietnam.
We have Strataglas and have used Collinite 925 till they changed their choice to Imar products. I do like it better, both the cleaner and the wax. As far as keeping it away from the metal frame, I use the plastic "c" fittings on the metal with the fabric side of sicky velcro wrapped on each one. We have 23 panels, so it is a job that is not taken lightly.
SunSox is the product sold to use on your SS frame to protect the vinyl windows. Some marine retailers have it but I don't think its in the BoatFix catalog. You can also use the foam pipe insulation held on with plastic wire ties but it's not UV protected and will breakdown in sunlight after a season or so.
I only used (and will only use) Armada 210 Plastic Cleaner and Armada 210 Polish on my vinyl windows. Unlike 303, the Armada products are made specifically for that. I've always had excellant results with 210.
Excellent feedback from all!
Sun Sox is what I was lookin' for... so thanks to all! Especially thanks for the idea of pipe-insultating foam. For the cost, I can get new every year! I think it even comes in colors. :-)
