Protecting rusting SS??
jtybt15
My SS exhaust pass under the engine hatch and water drips on it and my SS exhaust is rusting. I expect phosphric acid will clean and 'convert' the oxidized area but I was wondering if there is a specific paint that will also protect further oxidation.
Any ideas?
Thanky,
Depending on the ss alloy and the difficulty in removing the component, it can be passivated with Nitric acid (selectively dissolves the iron and allows the chrome component in the alloy to oxidize, protecting the surface). If you have a plating company nearby they can passivate the part for you--I don't recommend doing this yourself.
Do a search on passivation. You will find a multitude of opinions. It's worth looking to see if the source of the rust could be coming from something other than the SS that is being dripped on.
The SS is either 304 or 316. It isn't polished and has been welded and cut and re-welded to fit. I wire wheeled it but I don't think the wire wheel was very good SS so I have some areas that, as I said, are exposed to drip from the engine hatch hinge.
The phosphoric acid cleaned up the rust and because it never was polished, it's as good as it's gonna get. If it doesn't get any worse that it has, and the acid cleans it that easily, I expect to get good life out of this exhaust system.
can you fabricate a simple drip edge for the hatch edging to prevent the 'cause' rather than the symptom????
As I said originally, you need to use nitric acid rather than phosphoric acid. Phosphoric acid converts the rust and some iron to iron phosphate. You need to remove the iron from the surface as was done when the ss was manufactured. When you welded and wire brushed the surface you exposed the iron in the alloy--Nitric acid will remove it and allow the chromium to form a protective alloy.
OK! I'll look for nitric acid.
I'll look for a way to put in a simple drip edge, too.
Isn't there something about removing the oxygen or oxide from SS surface that makes it rust. Also, somehow to replace ??
Charlie, just cover the area with very heavy duty aluminum foil to keep the drips off!
I had a thread awhile back about repassivating some SS handles and nitric acid was recommended. Never did it as I was unable to easily locate a source. Where can one buy a small quantity of nitric acid?
Flutterby-- If you place 2 dissimilar metals in contact or near proximity with each other in a moist environment, you form a galvanic cell. The less noble metal, in this case aluminum, will quickly corrode.
Liz,
Not a very good idea of aluminum foil anywhere in an engine area where there are a lot of electrical connections.
Looked up the Wikipedia link-doesn't look like I'll be doing any of that!!!!! I've worked with different acids over the years, but nothing that volatile.
I have the same condition where small amounts of seawater drip on my SS y-pipe part of the exhaust. I made the y-pipe from 4" 304 alloy. I wipe it down whenever I open the hatch, which is fairly often, the orange stain comes off pretty easy with some Soft Scrub on a rag.
Larry
