Question about tying up
mandm1200
I have a question in regards to tying up? I am fortunate in that my daughter and her husband live and boat in the same area as I do. We normally tie up on the average on every other week. I have a small 26' cruiser and they have a 23' bow rider. We tie up using 2 lines; one towards the bow and one at the stern. It seems when wakes or waves hit while in 10+ mph winds the bow line get tight and jerks the boats. It becomes annoying after a few minutes of this. I think part of the reason is that my bow cleat is at least 2' higher than theirs. As their boat comes up on the wave it becomes a little slack. As the wave continues past; their boat is coming down while mine is going up. This creates the jerk.
As anyone used one of those elastic dock lines that give a little and will it work? Can someone suggest something that has worked for them?
The other thing I plan to try this year is to tie a 3rd line from my mid cleat to their stern cleat and try to take some pressure off the bow line.
Try tying up on an angle towards the bow.
So one bow cleat to a mid cleat.
Use two lines and criss cross.
Lines on a angle have less play than straight lines.
Also make sure boats are fendered off with 3 fenders.
The boats should ride on the fenders.
It all depends on where you tie up, the currents and the winds.
Just one off the bow and one off the stern is ok for a short
stop. When we tie off, we always start with a spring line off
the center cleat, then the stern line, then the bow line.
After that, we see how the currents and/or winds affect us and
then change up the lines from there.
Sounds like a plan. I think we were taking the quick, easy way. Using the criss cross or the spring line should improve the situation. Tying the boats up with lines bow-bow and stern-stern makes for very short lines and do not allow the boats to bob in the water independently without them getting very taunt. Spending the extra minute doing it in a better way will pay off.
Thanks!
Fore and aft spring lines with one breast line will solve the problem. If you want to use only a bow line and a stern line inserting a snubber in the bow line will help but not eliminate the problem.
Originally posted by mandm1200
Spring lines, spring lines, spring lines. They are your best friends. One from aft cleat fwd on one boat, the other fwd from the aft cleat on the other. Rig the bow & stern lines as loose as possible to allow the boats to move independantly. You are not trying to create a rigid raft.
A typical weekend raftup for us
"Lines on a angle have less play than straight lines."
I must be confused. I thought that the longer lines always had the more play.
G
Hmmmm, never thought of using spring lines in a raft up. I'll have to try that some time to see how well it works for my boat.
We have ten boats most weekends, sometimes more and we use spring lines all the time and also stern anchors.
We Tie up bow to bow and stern to stern with enough slack for the spring line. The boat at anchor or closest to the anchor springs from mid ship or there about to the tying up boats stern. You can then adjust your spring so your sterns or your boarding areas are parallel . Adjust your bow and stern lines and your done. As already mentioned fenders are your friend and buy the largest you can store. Something else worth noting since some may be new to tying up, the anchored vessel receives the lines and generally puts out the fenders. Depending on the size of the raftout this can be important as more boats come in and if you have to leave in a hurry because of conditions.
Billy K.
Over here one of the bigger boats anchors and we raft out on each side
getting smaller and smaller until the smallest is on the outside.
Works well until someone shows up late.
