Quick silver hr meter issue
jdidonato
I just had a 38' Sea Ray AC surveyed yesterday. The survey went well with one exception. The owner told me the generator had 1800 hrs, when the sveyr checked it read 3555 hrs.. He couldn't believe it was correct. We went for a sea trial, ran the gen with a full load the entire trip. When we got back the engines showed 1 hr., the gen 2hrs. All engines ran the same amount of time
Has anyone experienced this sort of issue with these generators, the surveyor said that would make sense, usually it is a two to one ratio between engines and generator. He told me he would bet this generator only has about 1500hrs.
My Quick Silver runs the correct hours. Keep in mind these were-are disposable promotional genny's that were a throw in deal from Merc. Parts and service is very hard to get.
Generac has the manuals and some parts.
JD - Did you have a chance to check the voltage at the hour meter as suggested when you made the same post in the engine forum? Check with full load. You might also check with Sea Ray to see if this is a common issue.
Did the surveyor charge for 1 or 2 hrs on that sea trial? j/k :D
depends if he was on the generator clock or the engine clock!
I will be checking the voltage at the hr meter on Friday. I will let you know what it reads. I'm also going to run the gen for an additional hour and take a reading.
