Radar Arch Lights
DancerDave
I have a burned out light on my Arch and am trying to find a replacement. It appears I will have to replace the entire unit since it looks like a sealed housing and the bulb is not accessible. My problem is trying to find one. It is for a 2004 Sea Ray and don't know if there are standard replacements for it or if I have to go thru Sea Ray. I haven't been able to locate any online.
Sea Ray doesn't make their own lights, they use others. In the past, I found replacements for my 1997 Sea Ray 290 Sundancer from Perko. If you contact Sea Ray with your hull ID, they will be able to tell you whose lights are on the arch along with the model #.
good luck,
you can download a parts manual for your boat from the service section of the main searay website. It will show you all the orderable pieces of the light and the bulb.
If you're faced with replacing the whole assembly, then look into replacing it with something smarter. Go with one that allows replacing just the bulb, or better yet, go with an LED unit. It'll consume less power and last probably longer than you'll own the boat.
There are some nice three color LED replacements that will operate using the same wiring and switch. It's kind of fun to have blue or red lighting while at the dock or underway.
I like the idea of some "mood" lighting. I think I will check that out. I went to West Marine this weekend and they want $56 each for the lights. I think I will either go with the color or go with a unit that will let me replace just the bulb since this will probably occur again.
