"Isn't that missing a "k"? I've never heard of a 1-watt radar." -- SLW
Actually the number is correct, there is no missing "k".
Keep in mind that while your 4kw scanner radiates at the rate of 4kw/sec, it does not transmit continuously, but in very short pulses. Very short; in the range of one onethousandth of a second ( or much less. I'd need to look it up... ). If you count all of the pulses issued during a one second interval, the total time actually transmitting is still very short. Which means that the average power is less than 25 watts. Think about it for a minute: How much current does your radar scanner/dome consume? What size fuse? Odds are, the scanner uses less than 10amps, less than 120watts, to power, not only the transmitter, but the receiver and the motor to rotate the scanner.
While the average power is low, you still should mount the scanner high for two reasons: 1) height = range. 2) It is -still- radiating at microwave frequencies and it is never a good idea to simply expose humans to it if avoidable.
And, imho, contrary to a post above, you should -always- use the radar, good weather or bad. But be courteous and place it on standby, or shut it down when rafted up or at the dock. Radar is a valuable tool for all conditions plus practice makes perfect.
