Radar Mounts
gawrys
I am going to install radar on the arch of my 1987 Cruisers Elegante. I need to use a 10" mount in order to get the radar dome above everything. What determines which type of mount to use, forward or aft, leaning?
Tom
Imaterial as far as function. Whatever looks best and clears everything.
The important thing is that the radar unit should be level when the boat is running at the speed at which you will most depend on your radar. It's one thing to mount it level when you're on full plane, but if you think about it, your most important use for the radar may be when you're in heavy fog and proceeding much more slowly.
BTG
As BTG explained -- mine is mounted on a 5 degree down slope so that when either very slow or on a proper plane it should be near level.
Mine is located on a hardtop and has no adjustment for running angle and works fine. When you think about this, the wave action causes enough change in the running angle that targets will show up or not show up depending on what the hull is doing.
Leaning aft transfers the shock of hull/waves so the force is more down into the mounting bolts rather than shear. The array on a 10" pedestal can have a lot of leverage working on the mount. In real life ,as long as it is properly bolted it may not make much diff. The vertical beamwidth of the transmission is usually fairly substantial so it always seemed optimum to me to wedge (if necesary) the mount so the array is at the average of level plane at rest and cruise, easily sighted close enough to the horizon and marked on a piece of cardboard held on edge to the mounting surface. No sense having it aimed at way at the sky and water when cruising if aimed best at rest. There are plenty of times when vis is just good enough for cruise speed but one still needs to know what is in that bank a mile or a lot more off. It's just an opinion.
My radar has a 12*-15* down angle. From a lot of experience running in the fog, small boats are hard to see at best of times and running in the fog with the bow high makes them invisable unless you have the center beam pointing downward and directly in front of you.
