Radio Checks....
Most common VHF problem is people having it set to International or Canadian. You'll pick them up close, but not at range as well as you would using the right channel set. (I'm assuming this wouldn't apply in Canada.
And the likely reason the CG was able to pick up a transmission when few other transmissions came through is that, as someone mentioned, they likely picked it up on a high site. (Elevated antenna)
Brad,
Doesn't seem to me that you did anything unreasonable. I usually respond to radio check requests on channels other than 16. Then I know my own radio is working.
A few years ago, I put together a ditch bag which includes distress signals etc but also I added a handheld GPS and handheld radio. I replace the batteries every spring and check them monthly during the season and before long trips. The handheld radio does come in handy when you call for a pumpout in a busy place like Block or Montauk and are waiting for them to get back to you.
"Breaker, one-six, looking for a radio check, anybody out there got their ears on???"
There have been many times that I have just turned off the radio because it becomes so annoying.
If your radio works on one channel, it most likely works on them all. Get a handheld and call yourself, you could test 16 by just keying the mike and listening on the other one.
Every now and then you'll run across, let's say exuberant, Coast Guard radiomen. Actually, a significant number of those who man the radios are civilian volunteers. Some of you may recall a problem we had in district one a few years ago where the CG was telling recreational boaters to not use channel 16 for hailing. I sent a letter to the Admiral heading up district one and that problem was resolved. This is a similar problem. There is NO regulation forbidding radio checks on 16. Of course some boaters abuse the system by requesting radio checks frequently. There are several good suggestions posted here for alternatives to a ch. 16 radio check. In the interests of keeping 16 clear and to avoid stepping on someone with an emergency, call your local towing provider on its channel, use your handheld, call your marina or any other alternative listed here. Use 16 as a last resort for radio checks.
If you ever get the chance to spend a few weekend watches in the COMM room you will understand why we say that...
AUX_MAN Out.
In the northern GOM the USCG must have repeaters or something. We can hear them from New Orleans to Tampa when they are calling. Tonight there was a 27 ft. Proline broke down, 70 miles south of the Mississippi River, taking on water. Two boats went to help. They were talking to the USCG in Mobile, Ala. first, then transfered to USCG New Orleans, then USCG Venice, La.
I could hear the whole thing, and they could hear the 27 ft. Proline all the way in Mobile, as well as the two boats rendering help.
The boat was 6 miles from us. I could hear him for about the next 20 miles, that's when he went off our radar, but could hear the USCG the whole time.
You heard New Orleans from the Gulf of Maine? I've picked up Virginia plenty of times here in Massachusetts, but that's some impressive reception...
The Gulf of Mex, I believe, Mike..
Now if we're talking AM/SSB, anything goes!
Under "just my opinion"....:
If you feel the uncontrollable need to have a radio check in the middle of summer, please, please, PLEASE simply answer one of the other radio check request transmissions by the at least hundreds of other boaters in almost any given area that also can't help themselves making regular checks, rather than initiating one yourself and adding to the unnecessary congestion on many channels most importantly 16. If you don't hear one right away, wait a few minutes. Or heck, wait a few hours... you can do it if you try. . The chances of your radio system going bad since the last time you used it are there but miniscule per trip. I do understand some degree of wishing to confirm the use of what could be a major lifeline in the very remote need for emergency communications on a nice flat summer day by those who may not be entirely comfortable running a boat out there. However, it is excruciatingly obvious that most of the boaters making these requests for reply are themselves ignoring others's similar hails. Do you call someone everytime you turn on your cell phone just to make sure it works & someone can hear you, or frequently lift the receiver on your landline to check for dial tone & maybe call the operator? There must be an -itis name for this. :D
"When I request a radio check on my local channel (72) I say its for either a new installation or repair/testing. I usually get a fast response from someone who is usually helpful as to signal clarity and location." This just sounds sad to me when it's not for the given reason, and plenty of people do this daily if not hourly never even leaving the dock.
Edit: I'll add another emphatic suggestion for radio checks: If you do feel the need to request a radio check for reasons other boaters would agree are valid, please include the name of your vessel and the CHANNEL you are hailing on. A large percentage of boaters now monitor more than 1 channel and are likely scanning the water rather than the VHF display at the moment of your hail. Tough to respond if you do not include the channel (any time you hail on VHF for any reason.) More than 1/2 the checks I hear don't include that last.
Don't neglect to designate,mutually agree & move to a recreational working channel if on 16 and more than 1 quick acknowledgement reply to your RC call is desired.
Hmmm... things must be different in Canada: first, it's up to $5000 fine and/or up to a year in jail if you use your VHF without an Operator's Certificate ( ROC(M) ). And in order to GET that ROC(M), you'd have to know the procedures for calling on 16, including radio checks.
ACTUAL procedure would be to call the CC on 16:
"Vancouver Coast Guard, this is Coatue on one-six, over"
And VCC will direct you to a working channel (probably 83A)
OR, you could do the radio check on 83A to begin with.
Realistically, you could skip the working channel, since as someone pointed out: if someone answers, it's working:
"Vancouver Coast Guard, this is Coatue on one-six for a radio check, over"
And VCC would probably answer:
"Coatue, this is Vancouver Coast Guard, read you loud and clear, out"
druid
AUX_MAN Out.
So lying to boaters is OK? I thought the Auxiliary was about training and education, not misrepresentation.
