Raft up question
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
While looking at all the great pictures of the various raft-ups over the Labor Day Weekend, I am reminded of a question that has always bothered me about raft-ups. When you're in the middle of one, are you pretty much there for the duration, or do "raftees" come and go during the day? Never being part of one, I'm not sure what the protocol is.
No if you plan to leave the raft-up, you'd better be on the end; unless of course your rafting buddies are okay with moving their boats and resetting the anchor(s).
I prefer to be on the outside of a raftup. And since my boat is usually one of the smallest, that is not a problem. But when one joins a raftup, it should be considered a commitment to stay for the duration unless something different has been agree to in advance.
Leaving from the middle is not a problem. You just need to communicate/coordinate your departure with both of your immediate neighbors. Most often, you simply run a line from one of your neighboring boats, across your boat, and hand it to a person on the other neighboring boat. You back out, and the guy pulls the line to close the gap. No big deal, really.
Bob, I should add that from reading your posts, I would expect that once you leave, the party will be over, and the raft up will disband rather quickly. [:-bonc01]
Also if you have a smaller boat, you'll want to be on the sides of the raft-up. No way a little 10 lb mushroom anchor is holding a line of 4, 5, 6 yachts! ;)
people come and go out of raft ups all the time. It's very easy with express style boats and takes just a little more coordination for MY's or sedans but still easy to accomodate.
Thanks for the replies. Also, I don't see a lot of bowriders on these raft-ups. Are we allowed?
bowriders are allowed. They come in handy when any of the larger boats realize the did a poor job of planning and they have run out of or are near running out of necessary beverages and/or ice or worse...have a craving for hot wings!!!
It really depends on the setup of your boat if you want to invite yourself to a raft up. Is your swim platform big enough and in line with the rest of the platforms? If not, move to the end of the line.
Are your fenders the size of tic-tacs?...don't even bother.
Will you have lines ready?
Bowriders come in handy for many things as previously mentioned. Also work well as floating ashtrays and garbage scows.
Raftups are fairly easy to deal with. The biggest problem is getting boats rafted so that they are compatible with each other i.e. easy to step from one to another. Stern to stern does not necessarily work especially when platforms are far apart. Different types of boats don't always sit well together so they have to be a little fwd or aft on each other to make gates & cockpit steps line up better.
Backing out of a raftup, even with larger boats is no real big deal. The departee, depending if he has an anchor down or not goes fwd or aft as lines are passed between the remainees.
Then there is the 'moving' raftup where you can't be bothered to break up just to move anchorage a little way
Also Bob, while on this subject of rafting, if boats are rafted off of a wall or dock, the inside boat (first boat secured) will be the courtesy boat and grants to those wishing to raft off it and the other boats.
What is the proper ettiquette on a raft-up concerning boarding others' boats? Do I basically get (and give) free access to all parts of all boats to everyone? Can I use someone's head without asking, or is it even a no-no to ask?
No Bob. You would always ask to board or cross over. Treat it as their home as you would have others treat you and your home...
You should always use your own head when at a raft-up. Transiting from one boat to the next should be done via the swim platform if possible. Via the cockpit is sometimes needed but parents should not expect others to be handing the little kiddies back and forth over and over. We are all trying to have a good time, if your kids want to visit friends down the line go with them.
Entering someones cabin or salon without being invited would be in bad taste. Think of a raft-up as a block party, have a great time, enjoy the common and open areas but don't invade my space unless asked.
All about common courtesy and respect for others property.
Gotcha. Don't want to be a "cad" when I join my first raft-up. Is there some sort of initiation for raft-up neophites like me? Maybe gargle bilge water from the courtesy boat or something like that?
Yes Bob there is an initiation - as the newb to rafting you must bring for the entire raft up
1) Beer
2) Rum
3) Lobster
4) Steamers
5) Steak
You must also be prepared to bar tend for the entire raft up as well as be the chef for the entire raft up.
Newbies are required to bring enough beer for the entire raftup. Unfortunately the amount required for a successful HRCC raft-up would exceed the weight limit of most bowriders. Perhaps you could also tow a large tube filled with beer on ice? Just a thought.
You should make sure your cooler is full, and offer beers to anyone who passes by.
DO NOT use anyone's head without permission!
