Ratheon 630 Chartplotter Question
nakalat
I have inherited a Ratheon system with my recent '99 3988 purchase and would appreciate some advice from someone who has similar equipment. The system (vintage '99) includes a model 620 monochrome chartplotter at the lower helm, a 630 color chartplotter, and a raydata unit on the bridge. The raydata unit is a digital device providing speed, depth, and water temp, and is interconnected with the lower chartplotters with seatalk cable through a seatalk hub. This was obviously a state of the art system in its day. Here is the issue...
These old flatscreen monitors are not great in the sunlight and I have been thinking of moving the color plotter from the bridge to the lower station, and installing a newer bright screen on the bridge. The thing is, although the lower station 620 plotter displays the depth signal from the raydata unit, the color plotter on the bridge does not. (although this info is displayed directly from the raydata unit on the bridge). When I move the 620 to the bridge, it does not display this data. When I move the 630 to the lower station the data is not available.
The Ratheon operating manual has not been too helpfull in this regard. My simple logic has failed to come up with a reason for this. I had assumed that since these devices are connected to the seatalk hub, that they should all talk to one another. I have not crawled under the bridge dash yet to check how the cables are run, but thought there may be someone out there that has, or has had a similar system who can provide an answer to this puzzle.
Seatalk is an extremely simple system. It has only 3 wires. To wire it, simply connect all the reds together, the yellows together and the blacks together. On some systems you must introduce a DC voltage on the red wire. Some systems supply their own voltage. The hub provides no network management. It simply is a convenient place to connect all the wires. It sounds to me like you need to make sure your Seatalk is working at both location first, then trouble shoot display problems. I can probably help with specific questions but it been a long time since I'm used a 620.
Thanks for the comments Shake. I think I will need to get under the hood to see how the cables are run, but I can't help but feel there must be a programming issue here since the 620 displays the depth data at the lower station but when I switch plotters, the 630 does not show this data in the window where it is labelled. It is just shown as  ______ft.  The curious thing is, when I move the 620 to the bridge, it does not display depth data as it does at the lower station.
I'm a little confused what works where.
Does the 620 show depth at the lower station?
Does the 620 show depth at the upper station?
Does the 630 show depth at the lower station?
Does the 630 show depth at the upper station?
Are you sure they're connected via Seatalk and not NMEA?
From what you describe there is no data feed to the bridge.When you move the 630 below you might have to reconfigure it to accept data that is avaible at that location.Then you you need to cable the 620 to the network on the bridge. Enjoy!
Shake
The answers in order:
yes
No
No
No
Im not sure how they are connected except I have noted two data cables at the lower station and only one on the bridge. But i think it is most likely seatalk since it is all ratheon equipment. I do not need this data on the bridge since the Raydata unit is there. I would like to replace the 620 at the lower station with the 630 (color), and get a new chartplotter for the bridge with better/brighter screen.
Ironworks
I suspect you are onto it Ironworks. How do I reconfigure the 630??? The op manual just provides instructions for creating the window for depth. I can do that, but the window displays no data. I do not have the installation manual. Wonder if the answer may be there?
