Raymarine GPS chart plotter - operational problem
marykhubby
Hi Experts - need your minds / experiences...
I have a Raymarine C80 purchased new 4 years ago. This year I have incurred a nagging problem. When using 3/4 or 1 1/2 SM scales, the unit will cycle on/off automatically (sometimes repeatedly, other times, no issue). It seems to happen most frequently on the smaller scale settings (strange), and variation in boat speed, or turbulence from waves, seem to have no effect. Last year the boat position icon disappeared near the end of our boating season, but it's been OK since startup this year (not sure if this is related).
I have chased the power wiring to insure it is securely fixed (confirmed) and validated the terminals on the rear of the unit are properly locked in.
Here's the input I am looking for...
1) Has anyone else experienced this problem?
2) What did you do to fix?
Thx!
Don
Check their web site for software updates and download the latest available. You can run the problem by tech support as well but I would start with the update check.
What Tom said. I had the same issue w/my C70 installed in 2004. Raymarine came out w/a software update that year and that fixed the problem. Since then, I have installed all of the updates as they are released. If you have installed the latest software upgrade, then I would contact Raymarine for more information/help.
SUPER!
Thx Much. Don't know why I didn't think they might have upgraded software available. But that's why I ask dumb questions and get intelligent answers. Good to know I am not alone and there is a fix.
I am off to the world of Raymarine Website...
Don
Thanks guys. . . I have a Raymarine C80 that is magical. . . will remember this if problems develop.
Some are having some problems with the 4.25 ver. Raymarine has a notice about way points not working properly. My C80 at times is slow to update position, I'm going to change back to ver 318 untill some of the bugs are worked out.
Same here. The other day after waiting for 10 minutes to get a position I did a power off/on and everything went back to normal. Also I was note able to get the depth indications(numbers)on the chart even if I activated this function. I had to do a factory reset and everything got back to normal.... I may fo the same and go back to 318...thanks for the tip.
