re:
Don't understand the subject. But if you are talking about a boat winterizaton, YES. The pink is fine for Conn.
I use low tox Sierra for the corrosion inhibitors. I'm not putting that pink stuff in my engines.
Why not?
Because I want my engines to last. I want as much corrosion protection as I can get.
No corrosion inhibitors in pink?
Correct. Pink provides no corrosion protection.
Mikee has it as usual. And being RWC, my engines spend about half the time with the blocks full of water only. At least I can protect them somewhat when out of the water.
WELL DAMN!
For those who winterize, is there a chart or link that would aid in the winterization process? Lo (no) tox and corrosion inhibotors?
TIA
Didn't we have a complete winterization guide spmewhere at BE from George VanP?
Why is Anti-Freeze so Delicious? (Pink Stuff vs. Green Stuff)
http://www.slate.com/id/2103821/
Ethylene glycol is the ingredient that makes antifreeze tasty. Though colorless and odorless, the syrupy alcohol derivative—which is excellent at lowering the freezing points of vital engine fluids—has a sweet taste that jibes well with soda, juice, and other sugary beverages. As many concerned pet owners and parents are well aware, dogs, cats, and kids are prone to lap up puddles of antifreeze left on garage floors. Every year, 90,000 animals and 4,000 children ingest the toxic liquid; if not treated immediately, the consequences of the poisoning can include renal or cardiovascular failure, brain damage, and death.
For obvious reasons, there's been quite a bit of agitation for safer, less scrumptious antifreeze. One solution has been the development of antifreezes, including one called SIERRA, that replace ethylene glycol with propylene glycol, a liquid that's nontoxic enough to be used as a sweetener in children's cough syrup. But propylene glycol costs significantly more than ethylene glycol.
I always thought pink stuff did have a corrosion inhibtor.
From West Marine website:
Virgin propylene glycol blend protects against burst damage to -50°F. While just as effective as traditional ethylene glycol antifreeze, propylene glycol is nontoxic and nonpoisonous. -50°F Engine and Water System Antifreeze inhibits fouling and helps lubricate pumps and valves throughout your water and engine systems without harming the drinking water by leaving a toxic residue. We recommend you use this product full strength for maximum protection.
Protects against burst damage to -50°F (-45°C)
As effective as ethylene glycol antifreeze
Inhibits rust and corrosion and lubricates pumps and valves throughout systems
Mercruiser makes the pink stuff -50this from their site
Can I use propylene glycol (RV antifreeze) in my engine?
Propylene glycol antifreeze with a rust inhibitor is approved for use in the raw water cooling system for cold weather storage purposes ONLY. However, if your engine is equipped with a closed cooling system, you should always use a 50/50 mixture of ethylene glycol antifreeze and water in this system. Even if you don't live in a freezing climate, you should still use an antifreeze/water mixture rather than plain water. Antifreeze mixtures have superior anti-corrosion and boil over protection properties.
On a different thread, several RO's have stated they've used the pink stuff for years with no problems. I usually go with the non-toxic AF, but this year I made a mistake and bought the pink stuff.
I decided to put it in. I then queried folks on a different thread as to whether or not I should redo the whole process or just stick with the pink stuff and not worry about it. The consensus seems to have been to stay with the pink stuff in my FWC Merc 496.
Peter
This discussion compares to the synthetic vs dino oil, Pledge vs name brand vinyl cleaner, regular single ply TP vs RV TP, lay-up with full fuel tank vs whatever is in there.... and all those other debates we have on a regular basis. Those of us who are convinced that our way to accomplish something is "the right way" because we've never had any issues will continue to do as we prefer. The "newbie" needs to sort through all the posts made by the more experienced boaters and then make their own decisions.
To the newbies reading this thread and any others of this type:
Some of us tend to lean towards using what, in our opinion, is the safest method of accomplishing a task even though it may be more expensive, more difficult or appear to be overkill. We do this because we want to avoid risk at any cost or, perhaps, because we have been misinformed.
Some of us tend to use what may seem the less expensive or path of least resistance when accomplishing a task because it has always worked or we learned through the experience of others that using the more expensive of more difficult method is simply a waste of money, time or effort, or because we are misinformed.
We are here at BE to share ideas, experience and knowledge. We don't need to agree all the time so the reader needs to take in all the provided information, process it and many times make their own decisions.
Hope this helps....
