Refrigerator
fishingfever
There was topic awhile back about a household refrigerator to replaced the Norcold model that is about 52 inches tall. I found a Haier model that fits the cutout perfect. HRF08WNDWN. Ricky
I can’t find the thread but here is what I did with mine. It is an Avanti that I bought at Brands mart. The switch is from the inverter and is a three position two power source switch. I also put an outlet so I can plug a TV, coffee maker, etc. from the inverter. I'll get around to trimming it out in teak one of these years.
That is a great setup. I see more and more folks going the 110 only route with that fridge. It works great. I have one in the garage and have it set so cold, both compartments are freezing my oldest daughters wedding cake leftovers.
The Haier is 8.0 Cubic 51 high 24 wide 26 deep. With freight it was only $500 dollars special order.
12/120 volt combo unit or 120 only?
The Avanti model was a little smaller why I needed to trim the cutout some. The fridge is frost free and also has lights. I know they use a little more power but I like not having to defrost it. I usually run my genset anyway. The inverter works great while underway and the ice cream stays frozen. I did the install about a year ago but I know it was less than 250. I figure I can get a new one every 3 years for the next 5 years than the price of a new Norcold or like.
The thread your looking for is in the Cruisers Forum under Norcold Refrigerator Replacement. I ended up buying a new one, slid right in. Good Luck!
I replaced my Never Cold with a Magic Chef from Home Depot. The Magic Chef is the same width and about 4 inches taller than the Norcold. The only regret is I should have done it earlier. The Beer is much colder and the cabinet mod was easy.
I also replaced an old "no Cold" with an Avanti and inverter and really have liked the conversion. About $400 less total cost than replacing with a Tundra or other "quality" 2 way unit.
Delaware Jim
Delaware Jim, I'm thinking about doing the same thing on the 3607 that (barring any surprizes on the survey)I'll take ownership of before the end of the month. What inverter did you choose & why?
I replaced the Notcold with a 110v Frigidaire unit from either Home Depot or Lowes, $270 total or thereabouts. I used the existing trim from the Notcold, have had it for 2 years or so, works great, no regrets! If you didn't know it was OEM, you'd think it was.
