Well.....I know first hand that brake fluid will remove Imron. I am in no way recommending the use of brake fluid. But it sure will do a wonderful job on removing the paint, I however did not want it removed.
Nahhhh, the master cylinder decided to leak on the frame that I had sandblasted and painted. I ended up spending a couple of hundred hours redoing the frame. had to pull the body back off and all the drive train. I cant decide now if I have more time and money in the boat or the Corvette.
