I had a water intrusion problem from upper deck leaking stanchions on a boat I bought. Water had gotten into the plywood core and was oozing brown liquid from a teak rubrail down the side of the hull. The hull sounded solid during the survey, so I figured if I could fix the joints, it would be OK without major destructive repair. I had the boat in inside heated storage drying out over last winter. I removed the stanchions, dried out the core I could see and overdrilled and filled the holes with epoxy before rebedding the stanchions. While I was doing that, the yard AwlGripped the hull. Even though I stopped future water entry, some residual liquid leaked out and stained the AwlGrip hull before it later stopped oozing altogether.
Is there anything I can use to remove these stain streaks from the AwlGrip paint without harming it? The proprietary AwlCare didn't touch it, nor did MEK on a rag and then flushed with water. Any suggestions?
Tom
Tom
