Ritchie compass adjustments
TomKat
My compass is off about 15degrees when compared to a gps known heading. I have obtained the instructions for compensation from the Ritchie website and would like to try to adjust it. Has anyone else played with the compensators? If so were you able to get the compass adjusted properly? I don't want to start adjusting and find out I'm really screwing things up. Any tips you have would be greatly appreciated. Thanks in advance. Tom
Make adjustments using very small, tiny changes to the compensators...it doesn't take much input. Also, have a good hand held compass...like one used to orient a map...as a reference point. GPS is no good unless your moving and you have to be stationary for this.
Make sure that you have your GPS set to magnetic, not true. A 15 degree variation East or West from true is not unusual. Also be sure to crank in the variation change for the years since the chart for your area was printed. Also compass deviation will vary depending on your heading, so you can't just crank in a single adjustment. (I see you've got the Ritchie instructions, that explains it.)
One more thing, iron deposits in certain areas of the Great Lakes can really throw a compass off in various places. Consult the chart for your sailing area.
sorry for highjack...
My compass has a big bubbe in it.. What do you use for fuid in these things ?
Mineral Oil. Call your compass' mfgr to verify what they use. May be best to take it in to a shop that services compasses.
I tried to do that on my first boat and my compass was never the same or correct! It is a lot harder then it seems, IMHO.
One my next boat, I've just left it alone. Make sure you do not have something magnetic such as speakers or a VHF radio near your compass. And things like fans will interfere. The motor affects the compass magnet.
TomKat,
There is no such thing as a "GPS Heading". GPS can only provide you with a Course Over the Ground (COG), which can be influenced by wind, current and antenna movement due to rolling, heaving, surging, etc. The proper way to swing your compass is to take magnetic bearings of objects (with a handheld magnetic bearing compass) and compare them to the charted bearings from a known location (a range line works great for this). Be sure to take into account the natural variation of the area, factoring in the annual change in variation. Also be aware of any areas on the chart that say "Local Magnetic Disturbance". Typically, compass adjustments are made with all of the electronics running. Draw up a deviation chart and keep it onboard, near the helm.
Make sure you only correct 1/2 of the error at a time on a particular course then go to the reciprocal, repeat , repeat. Do the same on the perpindicular headings. If you try to correct all at once you will never get there & ironically only make the compass error worse. Use a non-magnetic screwdriver.
Thanks for all the suggestions. I will be out this weekend and will try to make modest adjustments. Will post again next week with results. Tom
Q:My compass has a big bubbe in it.. What do you use for fluid?
A:Bubble means compensation diaphragm (most likely) or plug rubber seal(less likely) or dome o-ring (very unlikely) developed leak - order from manufacturer and replace. Compass before ~1990 used odorless mineral oil, after that - specially formulated ISOPAR L (or M - depending from the manufacturer). No washing inside compass requirted when changing liquids. For replacing diaphragm, turn upside down compass very gentle, and turn back the same way. DO NOT SHAKE COMPASS. Add liquid when replacing diaphragm. Replace bottom with adjustment rods into same position (mark it before disassembly) - then no deviation adjustment required. Unscrew plug and press slightly diaphragm to remove air, then tighten plug. Recommend to have protective cover over compass to prevent overheating.
