Robalo is a highly regarded name in the boating industry. However, no matter how well built a boat is, when it is 35 years old, it is almost guaranteed to have issues. In the '70's, in fact up until very recently, all outboard boats were built with plywood transoms encapsulated in fiberglass, many still are. Water intrusion, particularly fresh water (i.e. rain) gets this plywood wet, and it turns to mush--probably what happened to your Glastron's transom. If you are at all handy, it isn't such a big deal to put a new transom in a boat--of course, you have to figure out if the stringers are bad too--a likely scenario. At that point, you may be looking at rebuilding transom, stringers and floor--a fair amount of work and expense. So, if you want to fool with old boats, it pays to be handy with fiberglass. Now, as for the Robalo, someone with the right kind of moisture meter can tell you if the transom on the boat is wet or not--marine surveyors have these moisture meters. You also might find one at a local marina that does repair work. I would say it is lots more important to inspect the particular boat you are thinking of buying as opposed to buying based on a boat's reputation. JMHO.
