Rudder Lengthening
GonzoF1
I'm thinking of having someone lengthen my rudder by 2 or 3 inches to have it track a little more straight ahead than it does now. I don't want to add too much because I don't want to put too much extra force on the mechanisms like the bearings and the stuffing box.
Anyone ever do this to their boat?
*edit* Standard CHB trawler. Talking about making it longer toward the aft and not deeper toward the ocean floor. Thought I might need to clear that up.
Considered it on Saint Max. No need after the trim tabs were enlarged.
Are you sure the rudders are aligned properly (toe in or toe out?
Add a little to the front of the rudder to help offset the torque you'll feel.
please tell us how the larger tabs helped. and how did you make them bigger ?
Be careful changing the size of your rudders. Speak with a knowledgeable builder or a naval architect first.
As Paul mentioned, check your rudders for alignment first. Along with making sure your over all steering system is tight. Is your steering mechanical or hydraulic?
Does it track better with the AP on?
On my 1986 Silverton the rudders are a bit small. I have heard of replacing them with larger rudders which made a world of difference at slow speeds.
i'm not sure rudders will make the boat track better. 99% of the time, tracking issues are not caused by the boat but by the driver who keeps over correcting back and forth.
it could also be a mechanical issue in the steering system, incl to much play or binding, which causes the captain to over correct.
if the rudders are too small, typically the boat will be unresponsive and sluggish.
I only have one rudder... so alignment isn't the issue. No AP (assuming Auto Pilot here). Hydraulic steering too.
remember that in going aft with the rudder you increase the moment on the stearing linkage. Torque = length * force
You said CHB, so I'm thinking that you are not planing, thus trim tabs likely not a big factor. What speeds are you running? Some advice here is valid, just not for your boat, so be careful.
Also, again since not planing, thinking that the usual worry about adding extra drag is not as big of a factor (rarely do you really want to significantly increase rudder size on a planing boat, the usual cause of wanting to do so is lack of training, not undersize rudder).
To solve the "tracking" problem....hmmm....count me as one who is skeptical that the rudder is the solution. I'm assuming that you are saying that the boat is wandering back and forth. That's often some kind of hull form related issue and unless the rudder shaft has a lot of play in it, I'm not so sure I'd blame the rudder. At least, maybe not in this case, or not exclusively.
+1 for taking the time to talk with a marine architect before spending money on solutions (especially if the solution may in fact not be ideal AND might ultimately not solve the problem you are trying to solve). Mechanics & marina's and related maintenance personnel and fabricators are not the same thing as marine architects and engineers. The 400 level skill is knowing which one you need. Sometimes practical hands on experience with what works wins out over design, but I'm not so sure in this case. Would be worth an hour consult to find out.
we added a skeg guard to a few boats with tiny rudder syndrome they worked great! slips on with 2 bolts we also urathane glued it to stop vibration. it drasticaly slowed the auto pilot down(was overcorrecting) yet did not hurt top end handling helped in reverse too
If your trawler has a deep forefoot, which I suspect it does, it might just be the nature of the beast. Our Mainship 34 wanders some, especially when there are a lot of wakes around, creating confused seas. What I have found to help is to put on a bit more power, enough to get some bow rise, she steers easier then. I am talking about a fairly small increase in speed, she wanders a bit more under 7 knots, when you get her up nearer 8 knots, things improve. Of course, the fuel burn is higher, but the old Perkins still doesn't burn all that much diesel.
Yea... She's a displacement trawler. So I don't think that drag or force on the steering will be a huge issue. I mean, I'm just talking about two inches or so. I've been TOLD this boat does have a slightly undersized rudder, but not by an expert. So I guess I'll try and track down an expert of some kind. She's a full keel and single screw (Senator 35'), so I might agree with surprise's idea that I may just have to deal with it. But I am NOT ruling out user error. I mean, what do I know? I've owned the old girl for only ten weeks now, but this idea to ask came from two trips in fairly heavy following seas. She was a handful. And I'd really like for a future auto pilot to now have to work so hard, even in flat conditions. I wonder if I can fabricate a bolt-on solution that will allow me to test out the theory?
A guy in our marina changed his rudder size, no help, turned out to be a pinched hydro line going to the rudder which caused air in the line. making the rudder longer will not help. The rudder pushes the prop thrust not the boat.
ok, this is my point. Tracking usually refer to the boat meandering around in calm waters... Some boats will stay on track as if on rail or AP for a long time, not deviating from course at all. Prop pockets usually affects tracking negatively for instance, rudders dont' have any effect on tracking.
control in following seas can be caused by undersized rudder(s) but i woudn't jump to conclusion just yet. It may still be an operator issue. try it some more before you go and modify your rudders and if you do, get the right advice, not from "some guy".
almost every boat will become a handful in following or quartering seas. sometimes, you have to actually shut off the AP and use all your skills to mimize the effects.
don't forget that pretty much all autopilots need to be calibrated too. They way the react in nice weather, isn'nt and shouldn't be the way you want them to react in nasty weather. Few weeks ago we had 6 foot breaking wind driven following seas. Autopilot adjustment is in the salon and I was driving on the flybridge. At some point it was not worth the effort to find the magical settings and I just took control. It was a real pain. Actually had to steer for 30 minutes.
You said the problem was most evident in fairly heavy following seas, so I think before I started changing construction I'd try it again in similar conditions but add a little speed. Any boat will be more difficult to handle with a following sea, just need to have it follow not so hard.
I did this with a 1984 Marine Trader 34 DC we used to own. I added 3" to the aft section and 3/4" to the leading edge. It made a world of difference. Our boat used to wander while steering a straight course in normal sea states. Throw in a little following sea or anything aft of beam and the boat would wander, regardless of the helmsmanship. We had hyraulic steering and had made sure our system was blead and the ram and mounting hardware was tight before making the change. This modification also helped with docking while backing and filling.
sorry did not see this was a trawler in that case you can go big our tug is 4.5x6
I know at least one Selene owner who has increased rudder size so it is not that uncommon.
I don't think there will be a problem with a modest increase but as others have suggested try different operating conditions first as you learn the boat. Following seas usually push boats around; it is the nature of the beast. Remember that in following seas the water may be coming at the boat faster than the boat is moving and stalling the rudder, net water flow over the rudder is reduced significantly. Adding power may help retain water flow over the rudder.
should you decide to add some area a little extra forward of the shaft will reduce force needed to offset the extra area aft of the shaft but keep the forward part a fraction of the added aft part.
