louis Schlotter
- Oct 24, 2007
- 28848
- 1
We have 2 Bronze Rudder Glands 1 1/4", that are leaking badley. No one seems to know "What size Packing and How many Rings" to install. We are useing 3/16"Packing Material.
The Lock Rings have to be loosened and moved up, so the Packing Gland can be backed off to "Install" new packing. The Problem is "If we Install more than 1 Ring of Packing" and screw the Packing Gland down, the Lock Ring will not go down on the Rudder Post to it's Original Position.
The Lock Rings have 2 Bolts, one on each side and the Rudder Post have been Drilled approx. 1/8" for the 2 Bolts to seat into.
Could the Rudder Posts have "Dropped"? And have to be Raised up, so that more Rings of Packing can be installed? Or should the Lock Rings be "Re-Positioned" to allow for more Packing?
We are doing this in the water, as we have always done.
We have owned several boats and have never "Repacked" Rudder Glands and Installed less than 3 Rings of Packing.
When we Opened the Packing Gland, there was "No Packing" left in the Gland. Useing a Packing Puller Tool, the tool hit Metal to Metal, this let us know all the packing was gone.
The boat is a 1988 Tollycraft, 32ft.Sportfisher.Twin Screw, Gasoline Engines. Please Advise and thank you. Lou Schlotter
