Rusty Propane Cylinders
Doc
Has anyone else noticed how rusty the $2.38 Wal-Mart 16.4 oz bbq propane cannisters are? My transom is covered with rust from the dripping cylinders. Other brands have plastic on the bottom to cover up the little holes that the rust starts around. Can anyone remember the brand that has the covered bottom. I am ready to pay more.
Someone on T&T bet that the ones that rust were made in China. Nope. Says in big letters Made in USA by Worthington Cylinder Co, Columbus, OH
I work for Worthington Industries as a pilot but will pass this information on to the proper people in our cylinder division.
This is what I do to keep propane cannister rust from getting everywhere:
Over and above vent holes, I note that that the lid is a friction fit to container. When lid is removed a static charge can be created between lid and container, creating an electrical discharge when lid is removed--not safe when residual propane is in container.
Is this rusting problem something new this year? I've used Wal-Mart propane for years and have never had a rusting problem. I still have some canister I bought 3 years ago. No rust on any of them........
sitting right near the quart cans of acetone on the bench, too..!?
See what u get for trying to be helpful!!!!
UR welcome .... : )
Jeff..........I think its a GREAT idea......just needs a few vent holes on the sides and the upper cap.
Now I know what to do with all my small pieces of PVC.........thanks
Have read a lot of stuff on leaking propane and that it will funnel down to lowest point - bilge and how dangerous that can be. Most say that cylinders sould be over the side. I would think that the mostly source of leak would be when connected to a barbeque and that is where you should have it over the side. Most posts I've read say that stored ones should be also. Has anyone heard of new 16.4 oz propane cannisters actually leaking when disconnected and plastic top put on?
YES! Those cannisters OFTEN leak when disconnected...I regularly found empty cannisters in the PVC storage tubes (which BTW are vented and stored outside). You can listen for the hiss, and/or rub soapy water over the valve to see if they are leaking. If they are leaking you can poke something (wooden) quickly into the valve to see if it will reseat, but even if it does reseat it can start leaking later on it's own.
And hey guys, thanks for the concern, but as of a month or so ago, I removed all my propane cannisters from the boat...I realized I hadn't used them in over a year, since I went electric (which I understand isn't too popular with a lot of you either).
http://www.boatered.com/forum/topic.asp?TOPIC_ID=108527&whichpage=2
And thanks DD -- these guys are a tough crowd.
It's just a Schrader valve in there. Propane also has a fairly low UEL. I think this is one for Mythbusters. I don't think it would go POOOOF unless the valve seat was slowly leaking aand the container WAS vented to allow enough air for combustion.
But I also, admittedly, don't really know what I'm talking about. Would love to hear the opinion of someone who does.
Just made a recon run to K-Mart in Marathon. Coleman and K-Mart brand, each about $3.28, have a plastic cup on the bottom.
