Screwy Tach
BUBBA
Last Spring after sitting all winter the tach on
the port engine was pegged.This was before the first start up and it never moved. I gad it replaced with a new tach and it instantly did the same thing. Why would a tachometer do this ??
+1 a bad connection or a bad sensor. I had this happen on diesels. The wire going into the Glendenning synchonizer tach was loose.
What kind of motor do you have it could be your ECM module. I helped a friend trouble shoot his and I ended up swapping the ECMs between motors and the problem switched to the other motor.
Any tach problem I have ever had was the ground wire.
Thanks Guys I will check the ground wire. Too old to be ECM's 1984 260 Mercruiser
Some of those tachs have a rotary switch on the back for 4-6-8 Cylinders. Sometimes cycling it through the choices a few times and going back to 8 may clean the contacts and put it back to work.
What j-d said. I have had this problem several times. I have even gone to the effort of removing the rotary switch and soldering a jumper wire in place when I could not find a replacement tach that matched.
While we're on the subject, my tach is a little jumpy. The engine is running smooth, it's just the needle has a twitch. What do you guys think?
Thanks J-D but this is with a brand new tachometer also tried resetting the rotary switch and did not fix the problem
What kind of engines ?
If gas IB or I/O with older distributor, a warn rotor shaft and bushing-bearing will cause a "nervous" tach needle.
If you feel any side to side ( not rotation) play at all in the shaft, that would confirm it.
