Sea Ray THROTTLE
Rwillis
I have an '87 Sea Ray 270, twin 305's. The buttons on the sides of the throttle levers have been getting harder and harder to push in and finally have gotten IMPOSSIBLE. Therefore I can't get the throttle to work JUST the engine....pump the accelerator, warm up the engine etc. Any idea what is wrong and how to repair it???? thanks, Rob Willis
what brand/model control is it ? builders don't make their own engine controls, it's all off the shelf. yours may not even be original.
start by pulling the cover, cleaning the gunk or corrosion and greasing it.
"The buttons on the sides of the throttle levers"???
What buttons?
david, he's probably talking about combined throttle/gear control where you have to push a button on the side to disengage gear and increase idle in neutral.
Probably just take it apart, clean the salt/dirt/old grease out of it; relube and reassemble.
Thanks Pascal. Agree. Take it off, take it home take it apart and clean it well. Additionally, after you get it off take the shift cable off the engines and see if they are binding. If the cables are 21 years old, they may be worn beyond repair.
If so, I hear the Teleflex extreme are great replacements. If they are salvageable, try RO "OLD HOUSBOATER's" cable lube contraption.
http://www.boatered.com/forum/topic.asp?TOPIC_ID=95043
They most likely are Quicksilver/ Merc throttle/shifters.
If It's the button at the pivot point of the lever it'll pull out. Most likely, there's an allen screw holding the lever in place.
Thanks guys.....They are the orig Quicksilver-Mercruiser setup. I pulled the buttons off and looked under them...clean with grease. Inner and out splines for the throttle and the gear... Don't know how to "remove" the whole thing. There must be bolts/nuts under the assembly accessable from somewhere.... Sure was hoping to get the damm buttons to work without tearing the boat apart...
If I do have to remove everything I will replace the cables, thanks.
