Setting stern anchor
san
What's the secret to setting a stern anchor once the bow anchor is set and tied off?
no secret, just common sense.
If your main anchor is already set a the bow, dropping a stern anchor is not going to accomplish anything since you will not have enough scope. The only thing it's going to go is limit how wide you will swing on your bow anchor.
if you want to keep the boat lined up with little or no swing, you need to set your bow anchor, fall back much farther, set your stern anchor then reduce bow scope. ex... if you need 100' of scope... set the bow fall back 200' while paying out scope, drop the stern anchor and move back up 100'.
on a small boat you can also do it the other way... drop the stern anchor, pay out scope while moving to where you want to drop your bow anchor, then fall back halfway between. This will work on a small boat where you can pull the boat back and forth manually, it can be tricky if you have to use the engines as the risks of fouling a line in the prop are higher.
or if you have a dinhy... deploy the stern anchor from the dinghy after the bow is set...
Another option is to set the stern anchor with the dinghy. In my sailboats, even up to 62 feet, I always set the stern anchor first, had enough rode to let out twice the scope needed (a reel on the stern handled this line)--and then we went all of the way foreward under complete control, and set the bow hook, backed down, taking in stern line as we went--this is a two person operation--at least. The dinghy can be a one person operation. Take the anchor, chain and line in the dinghy--don't try and tie it off to the boat. You have to good at estimating distance, don't end up short!
Another dinghy approach.
Oftentimes I'll be blissfully swinging away on a main anchor when another boat anchors in too close. Happens a lot on the big boating holidays.
It happened last week.
I was stern to the bank in 15' of water. Shoreline was less than 100' away. Half of the distance was too shallow for the boat and full of underwater weeds. I didn't want the boat near there with power or not.
I was boating alone and left the Achilles at home, but there are always a couple of Sevylor Super Caravelle inflatable row boats on board, used for fun and exercise.
I got into the inflatable boat and pulled the 8 lb. danforth clone and chain onboard. Remembered to wrap the anchor in a towel so it didn't puncture the thin PVC boat. The anchor line was cleated to the boat and coiled to pay out. I shackled the line to the anchor chain and rowed out, pulling the line from the coil on the boat. I just dropped anchor near the shore where I wanted it and rowed back to the boat. I set the anchor with a few good pulls and adjusted the line where I wanted it. Pretty easy with a small stern anchor. The Achilles would have been a lot better with a larger anchor.
It's never a bad idea to mark those stern anchor lines with a bouy or float.
I've had lots of practice deploying a stern anchor from my boat while alone. Everything has to be planned out ahead of time to get it right and I don't recommend anchoring alone in a wind unless there is lots of water behind you!
I have a brightly colored float attached to the bitter end of my stern anchor rode. This allows me to ditch the anchor if I need to regroup.
I deploy my stern anchor first, keeping rode out of the prop by holding it across my shoulder as I go back to the helm. As I drive the boat to deploy my bow anchor, I am feeding stern rode out over my shoulder. Then I deploy my bow anchor and shut off my engine. I begin pulling in stern rode as my windlass pays out bow rode. When I get the boat in my preferred position between the bow and stern anchors, I cleat the stern rode to a side cleat [th]. Then I bring the bow line snug and secure it to a bow cleat. This setup allows me to adjust the boat closer to bow or closer to the stern as conditions change. I do not have a dingy or other floaty on board.
Another important consideration when anchoring bow & stern is chafe protection. On many boats swinging on one anchor does not present any chafing problems as the rode over the anchor roller does not come into contact with the sides of the anchor roller/pulpit setup, because the wind on the bow always keeps the rode pretty much centered. With a stern anchor out, and the wind off the side, the bow rode may be stressed against something hard which can chafe.
I learned it the hard way. By the time I got back to the boat after some time on the beach, 2 out of 3 strands were completely severed.
I advise against riding with an anchor rode taking the strain thru a bow roller. A better plan is to use a snubber. In the case of an rope anchor rode, you can use a slightly smaller 3 strand line, and tie this to the main anchor rode with a rolling hitch. This snubber keeps any chafe from the primary anchor rode. You can put the snubber thru chocks, from a fordeck cleat on the railing, etc. If you must ride to the main rode thru a roller, then put chafing gear over it- 1 1/2 to 2" fire hose works very well. Plastic tubing is too stiff and potentiall brittle to be the best choice. Chafing gear should be used whenever there is risk of chafing a rode--not just when riding to two anchors. In my current smaller boats (25 and 27.5 feet, I have snubber lines which go to the bow eye, where they are secured with a shackle and a thimble, with eye splice--no chafe. Even in some of my larger boats, I have rigged a snubber to a point of attatchment near the water line. This decreases the amount of line you have to have out by the height of the bow off the water x 7, eliminates chafe, and gives a much better "ride"--less "jerking" on the anchor pulpit--and I have seen pulpits damaged in heavy condition when loaded rode was thru them.
I know you are a very cautious boater Flutter, but a carefully developed anchor system and using it right has given me some justified confidence in my anchoring.
The way I think of it, if a boat is properly anchored in the calm, it will be just as anchored in the wind. Either way, a correctly anchored boat won't go anywhere it shouldn't go. It's when the boat isn't anchored that trouble happens.
Besides, the Calforina Delta is not the ocean or a large bay. There will not be a "lot of water behind you" anywhere you anchor out in the Delta. If a boat is drifting loose in the middle of the night while everyone aboard is asleep, is it going to make any difference if it takes five minutes to run aground or thirty?
yzer, my comments were referencing conditions before and during the anchoring process! Because where we boat, the areas are usually rather narrow and lined with rocky levees, I just don't even try to anchor by myself if it is windy. Once my anchors are set, let the wind come up. I know I'll be fine! And I can always pull closer to the tules as a wind break if necessary.
BTW, your "new" transom looks awesome!!!!
Not telling anyone.
Depends on your boat and the conditions and how familiar you are with the anchorage and how long your lines are.
My current boat is such a pain to anchor so I drop a bow anchor, let the wind push me back then use the dinghy to carry out the stern anchor.
My previous boat had a real nice windlass and a chain locker big enough to handle a few hundred extra feet of line. I would drop the bow, then back off to a reasonable scope, cleat the line off, then set the anchor by pulling firmly on it. Then I would let out another 100 feet of line and drop the stern anchor, then pull up on the bow to get to the end of the stern line.
The boat I had before that one didn't have a windlass or a big enough chain locker for that operation. I would set the bow anchor, drift back to reasonable scope (note that I typically anchored in 15 to 20 feet of water) and then set the anchor. Next I would tie the bitter end of the stern line to the bitter end of the bow line, the back up until I was out of stern line, then drop the stern anchor. Now I pull back to the knot, seperate the two lines, tie the bow line to the bow cleat and stern line to stern cleat.
If you don't mind having a large amount of anchor line coiled up on the back deck (or perhaps you have a stern chain locker...) you can drop the stern anchor first, move up to the bitter end and drop the bow anchor, then drift back to a spot halfway in between.
How easily all this accomplished is often a factor of how well you can handle 100+ foot lines and not have them tangle. When I handle my lines all works well. When a well intentioned guest gets a hold of my line it usually end up a mess.
Rod
IMHO and experience I caution you to think carefully about a stern anchor.
I had a bad experience with a blow comming up after dark, I had both new bow and stern 5/8 nylon lines and as the night progressed I felt a serious move, jumped from my bed to find the bow line had been completly cut by chaffing. The wind had shifted and was abeam, the stern anchor held and swung me into the boat anchored behind me. Lesson learned.
My new setup is 200 ft of chain, an anchor snubber and chaffing protection if I put out a stern line. If I expect a blow, no stern line, ever! If I put out two anchors they are both to the bow and set about 30-45 degrees apart.
Georgian Bay is unforgiving... you don't get many second chances.
"What's the secret to setting a stern anchor once the bow anchor is set and tied off?"
Keep it firmly and securely mounted in it's deck mount. Or use two anchors off the bow.
Sorry. I really don't trust having a boat anchored bow and stern...
sure, you can just drop off by the stern. it's not going to hold anything though....
I have a fortress FX7 for the stern with 5' chain and a nice mesh bag to hold it all. Depending on my mood I'll either jump in the water and set the anchor by hand, use the dinghy or simply heave the sucker a bit...it's not holding much so heaving works.
