Sheared Hub (Pics)
SHEP
This redefines "spun" hub - this is sheared hub.
Now - should this be covered under warantee? It is obvious by looking at the blades that I did not hit anything......
Volvo uses a front prop hub on their Duoprop? Bad idea...MerC has very robust prop shafts and both are splined.
You also have some corrosion under the paint on your port drive ;)
They will probably ask how fast the engine was turning when put in gear. That said, it still shouldn't shear rather than just spin the friction hub I would think, and would appear to indicate a manufacturing/design defect since there was no strike. That is a Duo-prop, yes? (Never seen one with props off.) Curious- does Volvo use a thrust washer forward of the forward prop? I don't seem to see anything like that in the 1st pic.
I can't see the pics but I have seen the prop eat the drive when someone forgot to install the spacer washer in front of the prop.
Looks like the prop came into contact with the lower housing, and the increased friction caused by the contact sheared it off. Was the prop installed correctly? (i.e.- Thrust washer)
MJK
King- I wondered about the thrust washer above , but if the hub shears like that in fwd gear the prop is going to contact the L/U washer or no, no?.
Charlie, the pic doesn't look to me like there is a washer/spacer ahead of the forward prop, if that part looks anything like the ones I'm familiar with on MerC and JohnRude with single props.
Looks like improper installation. When the hub failed the rear prop suction would suck the prop aft. Thats assuming this happened in forward gear. In reverse you would see that type of damage. you should know when this occured, If at speed, you would have noticed. Did this occur during low speed manuvering?
When we took off from our dock I noticed a thump... we cruised to our destination, then when docking i noticed what sounded like the prop running aground (in reverse) - I trimmed up the drives and did not notice any difference - on the way home, same thump, then docking again the sound of what appeared like the prop running aground - When I pulled the boat up on the lift i noticed that the two drives did not look identical and that the Starboard innner prop was further inside the drive - upon closer inspection......
What does the thrust washer look like?
here is another picture of the inner prop from the side..
No thrust washer on VP DP. Installation looks to be correct based on the forward nut location (thread protrusion). Could have been damaged by hitting something soft....partial damage which worsened over time/use....difficult to say for sure. I would not have guessed the spokes to be the weak link in the system. It would be nice to find out if this is a common failure mode or if something else usually gives away first. The prop will always try to move forward in forward gear which is why contact was made with the lower gear unit. My guess is that you just need to have the prop re-hubbed.
Mike, VP forward shaft is splined. Picture shows prop hub still installed which is why the splines are not visible.
The Thrust Washer is located forward of the prop, recessed into the prop hubb's leading edge, it will be just larger than the shaft diameter and about 1/8-3/16 thick. The thrust washer can fall out sometimes during installation as there is some tolerance in the recess in the prop hub. you will notice once you remove the old hub portion that the forward seat is deformed. (if there was no washer)It would also help if you posted model, DPS? DPG? X?
I see, so the prop basically sheared apart? The shaft isn't even damaged...right?
It should look like this (sorry, it's the only picture I could find.)
Yes, no damage to the shaft and as usual no pushback when it came to claiming it under warantee.....
Very nice. Are they sending you a set of props or just the front one?
Since it was the inside of the hub - they are simply replacing the hub.....
