BombayBlue
- Nov 5, 2005
- 19472
- 29
Hello,
'96 Mercury 200 outboard.
Replaced the water pump and I am having trouble lining up the upper and lower shift shafts. Looking at them I can definately see that they are off and will not line up. Not sure what I did to get them that way.
Working with SELOC as a guide, I have a Cam-Shaft system. I removed the lower unit with the remote in Forward and it has not been touched since.
Pump replacement went without incident. Now the upper and lower shift shafts do not line up.
SELOC recommends "place a punch against the upper shift shaft and then strike the punch with a hammer to help align the shaft." Tried gently tapping both the upper and lower shafts. They do not move. Tried to turn the upper shaft with pliers and it does not move.
I have looked through some of the forums and rotating the prop is a suggestion. What has me really worried now, is that when I rotate the prop clockwise or CCW it is free spinning, like it is in neutral. Drive shaft does not spin.
The upper shift shaft does not seem to move at all. The lower shift shaft will not turn but does pull up and then will drop back down (not turning in either the up or down position.)
Any suggestions before I decide to take it to the dealer????
Many Thanks --
Many Thanks --
